USB Port Not Working - 1941
pd4294
I have a new 1941 that the USB data ports are not appearing.
It is running 15.4
The following results are with flash drives plugged into the USB0 and USB1 slots.
In doing a DIR, get the following listed:
dir ?
/all List all files
/recursive List files recursively
all-filesystems List files on all filesystems
archive: Directory or file name
cns: Directory or file name
flash0: Directory or file name
flash1: Directory or file name
flash: Directory or file name
null: Directory or file name
nvram: Directory or file name
system: Directory or file name
tar: Directory or file name
tmpsys: Directory or file name
xmodem: Directory or file name
ymodem: Directory or file name
| Output modifiers
<cr>
(No reference to USB drives)
Sh USB Device 0 (or device 1) gets:
Device not found
Show USB Port 0:
Port Number: 0
Status: Enabled
Connection State: Connected
Speed: High
Power State: ON
Similarly, Sh USB Port 1:
Port Number: 1
Status: Enabled
Speed: High
Power State: ON
Sh usb controllers 1:
Controller ID: 1
Controller Specific Information:
USB port 0
USB registers
USB CLCK CNTL: 0x000000000002683D
USB GAHBCFG: 0x0000000000001408
USB GUSBCFG: 0x00000000000001A1
USB GINTMSK: 0x000000008BC744A0
USB HCFG : 0x000000000000EA60
CONTROL TRANSFER Statistics
Success 6, Crc 0, Bit Stuffing 0, Stall 0
No Response 0, Overrun 0, Underrun 0
Buff overrun 0, Buff underrun 0, Cancelled 0
Invalid Handle 0, Host hw error 0, Semaphore timeouts 0
Default errors 0
BULK TRANSFER Statistics
Success 0, Crc 0, Bit Stuffing 0, Stall 0
Default errors 0
INT TRANSFER Statistics
Default errors 0
While not having the USB running is minor, I would like to be able to get everything working properly.
Thoughts or suggestions?
Thank you
Leo Laohoo
Cisco routers are particularly "sensitive" to what type/brand of USB thumb drive used.  The thumb drive may be "supported" in Cisco switches but it is no guarantee the same thumb drive will work with routers.
Newer IOS has the ability to disable the USB port.
according to the post below,it is a software bug, and you need to down or upgrade.
https://community.cisco.com/t5/small-business-routers/can-t-access-usb-ports-following-upgrade-1941-router/td-p/3013968
Leo Laohoo
I want to know the exact firmware version.
What are you plugging in, a USB thumb drive or a USB HDD?
A variety of USB Flash Drives. 4GB, 8GB, and 16GB.
I had formatted one of the 16GB drives to have a 4GB FAT16 partition, based on what I had read on another post.
the flash drives work fine in a G350 switch.
Leo Laohoo
