Vlan command issues
sintel001
The exact commands given where
CMERouter1#config
CMERouter1(config) #interface vlan 1
% Invalid input detected at '^' marker.
The setup for the vlan database names worked fine but when I did a
CMERouter1(config) #interface ?    : there was everything but no vlan choice in the response
Sajid Ali
Hi Sintel0001,
Do you have any HWIC card at router?
Always rate helpfull posts
Sajid Ali Pathan
This discussion has been reposted from Cisco User Groups to the WAN, Routing and Switching community.
i've observed for quite some time now that some older posts are re-surfacing.
can CSC moderators do something about this?
John
I suspect that the CSC moderators are the ones who are causing this. It appears that a major cleanup is in process and posts are being moved to more appropriate forums. I agree that it is confusing when so many very old posts show up in the forum looking like new posts. I wish there were a way to silently move the old posts but I gather that this is not possible.
Rick
Rick
