Voice card issue - don't see ports even after configuring it.
gavin han
I don't see the voice card ports even after configuring it as follow:
Router(config)#card type t1 0 0
SURWAN(config)#voice-card 0
Router(config-voicecard)#codec complexity high
Router(config-voicecard)#dspfarm
Router(config)#controller T1 0/0/0
Router(config-controller)#framing esf
Router(config-controller)#linecode b8zs
Router(config-controller)#ds0-group 1 timeslots 1-24 type e&m-wink-start
%Configure network-clock-participate wic 0 first
after above configuration I don't see voice ports as in following commands:
Router(config-controller)#do sh voice port sum
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
PWR FAILOVER PORT        PSTN FAILOVER PORT
Router(config-controller)#exi
Router#sh ip int b
Interface                  IP-Address      OK? Method Status                Prot
ocol
GigabitEthernet0/0         10.10.10.1      YES NVRAM  down                  down
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down down
Serial0/1/0                unassigned      YES NVRAM  administratively down down
Serial0/1/1                unassigned      YES NVRAM  administratively down down
Serial0/1/2                unassigned      YES NVRAM  administratively down down
Serial0/1/3                unassigned      YES NVRAM  administratively down down
Router#sh voice port sum
                                           IN       OUT
Please advise.
Thanks....
Peter Paluch
I think the clue is right before our eyes:
You will need to add the network-clock-participate wic 0 global configuration command before entering the controller configuration and creating the timeslot groups.
Best regards,
Peter
Peter Paluch
Best regards,
Peter
