10-05-2010 06:09 PM - edited 03-04-2019 10:00 AM
hi all, router crashed a couple times today.
can anyone check to see if it is a software or hardware issue?
based on the address 0xB0D0B27 and output of show region, it could be a software issue?
ROuter#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 17:54 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
AAC-Aokea uptime is 50 minutes
System returned to ROM by bus error at PC 0x423A3528, address 0xB0D0B27 at 01:14:48 UTC Wed Oct 6 2010
System image file is "flash:c2800nm-adventerprisek9-mz.124-24.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 1036288K/12288K bytes of memory.
Processor board ID FTX1039A032
2 Gigabit Ethernet interfaces
4 Serial interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
254464K bytes of ATA CompactFlash (Read/Write)
AAC-Aokea#sh region
Region Manager:
Start End Size(b) Class Media Name
0x0F400000 0x0FFFFFFF 12582912 Iomem R/W iomem:(uncached_iomem_region)
0x3F400000 0x3FFFFFFF 12582912 Iomem R/W iomem
0x40000000 0x7F3FFFFF 1061158912 Local R/W main
0x40014080 0x443DFFFF 71090048 IText R/O main:text
0x443E4780 0x4711D05F 47417568 IData R/W main:data
0x4711D060 0x4849D01F 20447168 IBss R/W main:bss
0x4849D020 0x7F3FFFFF 922103776 Local R/W main:heap
0x80000000 0x8FFFFFFF 268435456 Local R/W main:(main_k0)
0xA0000000 0xAFFFFFFF 268435456 Local R/W main:(main_k1)
Free Region Manager:
Router#
Solved! Go to Solution.
10-05-2010 09:12 PM
I don't see 12.4(25b) in affected versions, so it should be OK, but keep in mind that you may be losing features moving from 12.4T to 12.4 mainline
10-05-2010 07:00 PM
Could be CSCsx19184 (http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsx19184) if you are running SIP
Fixed in 12.4(24)T1 or higher
If not, post a show run, info about any changes made recently
10-05-2010 07:55 PM
Looks like you are right! We are running SIP through the router and the code is at 12.4(24)T.
Will be upgrading to 12.4(24)T4 - thank you!
10-05-2010 08:09 PM
my cco access wont be available until monday, to download the latest software.
i grabbed 12.4(25)b off another router (c2800nm-adventerprisek9-mz.124-25b.bin)
can you check the bug toolkit to see if that version has the fix?
thanks!
-robert
10-05-2010 09:12 PM
