VWIC2-2MFT-T1/E1 work with 2951?
Patrick McHenry
Level 4
Level 4
I'm just double checking here because I saw one doc that didn't mention the 2900 on the data sheet but, I ve seen the 2900 listed with on others. I don't see the 2900s listed in this with the interface.
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
It can be used for either, in fact it is called Voice Wan Interface Card.
Thank you for the nice rating and good luck!
6 Replies 6
paolo bevilacqua
Yes, it does.
Raised another question. Could this interface be used for only data as well? I noticed that the interface name has voice in it. Can it be used for data only or voice only?
Thanks, Pat.
tsolution
Yes it works fine I tested personally.
Yes, it does.
On production environment at the moment. check the minimum IOS version you need!!!
Alessio
Alessio Andreoli wrote:
Yes, it does.
There is no minimum IOS version for VWIC2 support on ISR G2.
