WAN Load Balancing with 2 ISP
senthilmds
Hi All,
i have two isp connected to my router, i have Multiple Nat pools using route maps.
here is my router config
ip nat inside source route-map Nat interface Dialer1 overload
ip nat inside source route-map Nat1 interface Dialer2 overload
route-map Nat permit 10
match interface Dialer1
set interface Loopback5
route-map Nat1 permit 10
match interface Dialer2
my target requirement is load balancing with the two isp's like how UTM firewall does this functionality or similar.
regards
Senthil Kumar S
6 Replies 6
simonstoll
The probleme is that you have to asure that each connection always stays with the same ISP (address), otherwise your connections will get broken. I had to do the same thing but with 6 DLS link whith different adresse ranges to the same ISP. It didn't work fine until I used 6 routers for the DSL lines plus one (two for redundancy) which distributet the load to the six routers. That way we had a very cheap but fast internet connection. I don't understand 100% your config, why do you match in your nat route-map the dialer interfaces and set interface loopback5 as outgoing?
Best regards
Simon
Simon,
i have updated the post with my current running configuration,
the roue-map for dialer-interface is for selecting the appropirate nat pools and xlate the address. the wan links are terminated in a single router. you could also use route maps for multiple nat pools and get sorted out with using multiple routers.
regards
Senthil
kamlesh.sharma
Level 3
Level 3
suppose you have two different network in your LAN network x.x.x.x and y.y.y.y than match one of the network in one route--map and other one in second route -map than on lan side your load balancing will work .
for other help please give us specific information too.
please rate if it helps
HTH kamlesh
i have single lan you could ref the link below
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
multiple nat pools to support address translation at the internal segment. nat translations timeout, doesnt work for me. i have two default gateway, i need to load balance each destination address to take a path.
here is my current running configuration
ip subnet-zero
no ip source-route
no ip domain-lookup
ip domain-name test
ip audit notify log
ip audit po max-events 100
ip cef
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
vpdn-group 2
vpdn-group DDSL
request-dialin
protocol pppoe
interface Loopback0
ip address 192.168.105.1 255.255.255.255
ip nat inside
interface Loopback5
ip address 10.1.1.1 255.255.255.255
ip nat inside
interface FastEthernet0
ip address 192.168.100.10 255.255.255.0 secondary
ip address 203.187.x.x.255.255.128
ip access-group 100 in
ip access-group 100 out
ip nat outside
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Serial0
no ip address
shutdown
interface Virtual-Template1
ip unnumbered Loopback0
ip nat inside
ip load-sharing per-packet
peer default ip address pool default
ppp authentication pap callin
ppp ipcp dns 202.9.x.x.187.244.13
interface Dialer1
bandwidth 64
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username senthilmds@eth.net password 7 xxxxxxxxx
router eigrp 53
network 192.168.105.0
network 192.168.106.0 0.0.0.3
no auto-summary
no eigrp log-neighbor-changes
ip local pool default 192.168.105.2 192.168.105.254
ip nat pool INET 203.187.x.x.187.245.57 netmask 255.255.255.128
ip nat inside source route-map Nat1 pool INET overload
ip nat inside source static udp 192.168.100.9 69 203.187.245.57 69 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 203.187.245.1 5
ip route 0.0.0.0 0.0.0.0 Dialer1 6
ip route 10.0.0.0 255.0.0.0 Null0
ip route 172.16.0.0 255.240.0.0 Null0
ip route 192.168.0.0 255.255.0.0 Null0
ip route 192.168.100.3 255.255.255.255 192.168.100.9
no ip http server
ip pim bidir-enable
no logging trap
access-list 10 permit 10.1.1.1
access-list 10 permit 192.168.100.0 0.0.0.255
access-list 10 permit 192.168.102.0 0.0.0.255
access-list 10 permit 192.168.105.0 0.0.0.255
access-list 10 permit 192.168.200.0 0.0.0.255
access-list 21 permit 218.248.16.129
access-list 21 permit 203.187.245.57
access-list 22 permit 202.54.180.65
access-list 23 permit 192.168.105.2
access-list 100 remark Deny Virus
access-list 100 deny tcp any any eq 445
access-list 100 deny tcp any any eq 135
access-list 100 deny udp any any eq 135
access-list 100 deny udp any any range netbios-ns netbios-ss
access-list 100 deny tcp any any range 137 139
access-list 100 deny udp any any eq 1434
access-list 100 deny tcp any any eq 1434
access-list 100 permit ip any any
access-list 103 permit tcp any eq www any
access-list 104 permit tcp any eq ftp any
access-list 104 permit tcp any eq ftp-data any
access-list 155 permit ip 192.168.105.0 0.0.0.255 any
access-list 155 permit ip any host 10.1.1.1
dialer-list 1 protocol ip permit
match ip address 155
line con 0
line aux 0
line vty 0 4
no scheduler allocate
ntp clock-period 17180136
ntp server 192.5.41.209
end
regards
Senthil
Hi Senthil
Your config looks rather complicated :-) I d'ont understand exactly what is the inside of your network and where the two ISP's are connected as the only physical interface you are using is the ETH0 which is "outside", could you please clarify that a bit?
Simon
Simon,
it is not too complicated. it is my home network with two 128kbps internet connected. the problem is one ethernet interface, hence i use pptp tunnen to connect to the router and it becomes as a interface. rest the two wan connections are connected via ethernet and one via pppoe dialer1 interface.
if i have
ip route 0.0.0.0 0.0.0.0 di1 name dial-up
ip route 0.0.0.0 0.0.0.0 203.187.245.1 name ethernet-cable mode.
to nat the exact internal ip i use route-map to match the class.
do suggest me a method to load balance the internet. by acheving either destination based or packet based.
to get full 256k internet access speed.
regards
Senthil Kumar S
