Why is my interface state changing?
jaesposito
All,
I suspect that my DSL carrier is responsible for the dropped connection on my 837.   Is there anything I can use as evidence to prove this beyond the following log entries?
677464: Jun 20 09:17:54: %LINK-3-UPDOWN: Interface ATM0, changed state to down
677465: Jun 20 09:17:55: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
677466: Jun 20 09:18:42: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
677467: Jun 20 09:18:42: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
677468: Jun 20 09:18:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
677469: Jun 20 09:18:47: %LINK-3-UPDOWN: Interface ATM0, changed state to up
677470: Jun 20 09:18:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
677471: Jun 20 09:19:05: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
677472: Jun 20 09:19:05: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
677473: Jun 20 09:19:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
Below is the output from my 'show interfaces'.  Let me know if you need any additional information
Router-10031#sh interface
FastEthernet1 is up, line protocol is up
  Hardware is FastEthernet, address is 0000.0000.0000 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     4008 packets input, 0 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     19525 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
FastEthernet2 is down, line protocol is down
  Auto-duplex, Auto Speed, 100BaseTX/FX
     8488 packets input, 0 bytes
     0 watchdog
     24941 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
FastEthernet3 is down, line protocol is down
     208 packets input, 0 bytes
     0 watchdog
     1017 packets output, 0 bytes, 0 underruns
FastEthernet4 is administratively down, line protocol is down
     0 packets input, 0 bytes
     0 watchdog
     0 packets output, 0 bytes, 0 underruns
Ethernet0 is up, line protocol is up
  Hardware is PQUICC Ethernet, address is 0012.8032.d40e (bia 0012.8032.d40e)
  Internet address is 10.10.10.1/24
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Full-duplex, 10Mb/s
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 12
  Output queue: 0/100 (size/max)
  5 minute output rate 1000 bits/sec, 0 packets/sec
     4229852 packets input, 760442337 bytes, 0 no buffer
     Received 22349 broadcasts, 0 runts, 0 giants, 0 throttles
     5 input errors, 0 CRC, 0 frame, 0 overrun, 5 ignored
     4882284 packets output, 1521940913 bytes, 0 underruns
     2 unknown protocol drops
ATM0 is up, line protocol is up
  Hardware is PQUICC_SAR (with Alcatel ADSL Module)
  MTU 1500 bytes, sub MTU 1500, BW 1524 Kbit/sec, DLY 80 usec,
  Encapsulation ATM, loopback not set
  Encapsulation(s): AAL5  AAL2, PVC mode
  10 maximum active VCs, 64 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input 04:41:53, output 00:00:00, output hang never
  Queueing strategy: Per VC Queueing
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     4954190 packets input, 1596248379 bytes, 0 no buffer
     0 input errors, 21215 CRC, 0 frame, 0 overrun, 0 ignored, 1 abort
     5413283 packets output, 911039497 bytes, 0 underruns
     0 output errors, 0 collisions, 372 interface resets
  Full-duplex, 10Mb/s
     0 packets input, 0 bytes, 0 no buffer
     0 output errors, 0 collisions, 1 interface resets
NVI0 is up, line protocol is up
  Hardware is NVI
  Interface is unnumbered. Using address of NVI0 (0.0.0.0)
  MTU 1514 bytes, BW 10000000 Kbit/sec, DLY 0 usec,
  Encapsulation UNKNOWN, loopback not set
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Internet address is XX.XX.XX.XX/32
  MTU 1500 bytes, BW 1524 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, loopback not set
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi1
  Last clearing of "show interface" counters 17w5d
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1143 kilobits/sec
     4950056 packets input, 1427668224 bytes
     5406688 packets output, 851292867 bytes
Bound to:
Virtual-Access1 is up, line protocol is up
  Hardware is Virtual Access interface
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoE vaccess, cloned from Dialer1
  Vaccess status 0x44, loopback not set
  Interface is bound to Di1 (Encapsulation PPP)
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 04:42:16
  Output queue: 0/40 (size/max)
     10539 packets input, 1601176 bytes, 0 no buffer
     19647 packets output, 2518754 bytes, 0 underruns
     0 carrier transitions
  Open: IPCP
  5 minute input rate 2000 bits/sec, 2 packets/sec
  5 minute output rate 2000 bits/sec, 2 packets/sec
     10542 packets input, 1601326 bytes, 0 no buffer
     19650 packets output, 2520058 bytes, 0 underruns
     0 carrier transitions Router-10031#sh interface
     0 watchdog
     0 watchdog
     0 watchdog
     0 watchdog
  Full-duplex, 10Mb/s
  Full-duplex, 10Mb/s
  Hardware is NVI
  Hardware is Unknown
  Internet address is 74.164.121.125/32
Bound to:
  Open: IPCP
  Open: IPCP
7 Replies 7
paolo bevilacqua
Was it working ok before ?
Take "show dsl interface".
Also try another router/modem.
Paolo,
There is only a Cisco 837 connected to the phone line.  The 837 has a built in DSL modem on the ATM0 interface (Alcatel ADSL Module).  So there are no other devices to troubleshoot except the 837.
Here is the output from the "show dsl interface ATM0" command while the connection is up:
Router-10031#sh dsl interface ATM0
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT)
ITU STD NUM:     0x01                            0x01
Vendor ID:       'ALCB'                          'ALCB'
Vendor Specific: 0x0000                          0x0000
Vendor Country:  0x00                            0x0F
Capacity Used:   99%                             67%
Noise Margin:     8.0 dB                         16.0 dB
Output Power:    18.5 dBm                        11.0 dBm
Attenuation:     59.0 dB                         31.5 dB
Defect Status:   None                            None
Last Fail Code:  Message error
Selftest Result: 0x00
Subfunction:     0x15
Interrupts:      3322 (1 spurious)
Activations:     371
Init FW:         embedded
Operartion FW:   embedded
SW Version:      3.9.220
FW Version:      0x1A04
                 Interleave             Fast    Interleave              Fast
Speed (kbps):          1536                0           384                 0
Reed-Solomon EC:        436                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Bit Errors:               0                0
BER Valid sec:            0                0
BER Invalid sec:          0                0
LOM Monitoring : Disabled
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 4 5 5 6 6 7 7 7 6
10: 6 7 6 6 6 6 6 6 5 5 5 4 4 3 0 0
20: 0 0 0 0 0 0 5 5 6 6 5 5 6 7 6 7
30: 6 6 5 6 6 6 6 5 5 4 5 5 5 5 5 4
40: 3 4 4 4 4 4 4 3 3 2 2 2 3 3 3 3
50: 4 4 3 3 3 3 3 3 4 4 4 4 4 4 5 6
60: 7 7 2 8 7 8 8 8 8 7 7 5 8 7 6 6
70: 4 4 2 6 6 6 6 4 2 2 4 5 5 5 3 0
80: 0 2 4 4 4 2 0 0 0 2 2 3 2 0 0 0
90: 2 2 3 2 0 0 0 2 2 2 2 0 2 0 2 2
A0: 2 2 0 2 0 0 0 2 2 0 0 0 0 0 0 0
B0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Training log buffer capability is not enabled yet.
Your circuit has very high attenuation and will never work good as it is now.
Have telco switch you to a better pair if they have it.
Thank you for the information.  What attenuation figure is high (59.0 dB or 31.5 dB) and what should the figure be ideally?
James
http://www.naschenweng.info/2008/10/16/adsl-significance-of-snr-and-attenuation
please remember to rate useful posts clicking on the stars below.
hanks for the article.  That is a good read.  Of course, this gives me more questions.
Note that the output of the "show dsl interface ATM0" command displays two values for attenuation:
ATU-R (DS) = 59.0 dB
ATU-C (US) = 31.5dB
So I have four questions:
1.)  What is the difference between the two?
2.)  Which one is relevant for my conversation with my carrier?
3.)  Where can I see the "Signal to Noise Ratio" (SNR) on my interface stats?
4.)  How can I tell from my 837 router if Interleaving is enabled on the carrier side?
I will rate the posts and select a "correct answer" shortly.  Thanks for the help!
James
Paolo,
Can you answer the four questions in my last post?  Then I will rate your posts.  Thanks!
James
