Why offered rate more than Shaping rate ?
hatman
am set the traffic shaping as below but i don't know why the offer rate t can exceed ?
sh policy-map interface f0/1 output
FastEthernet0/1
  Service-policy output: pm_top
    Class-map: cm_icmp (match-all)
      18646 packets, 23677532 bytes
      30 second offered rate 3161000 bps, drop rate 0 bps
      Match: protocol icmp
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
          1000000/1000000   6250   25000     25000     25        3125
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         0         0         0         0         no
8 Replies 8
rsavena14
Can you paste your policy-map configuration?
-- configuration --
sh policy-map pm_top
  Policy Map pm_top
    Class cm_icmp
      Traffic Shaping
         Average Rate Traffic Shaping
         CIR 1000000 (bps) Max. Buffers Limit 1000 (Packets)
      service-policy pm_icmp
    Class class-default
Hi Manaschai,
Can you try removing the "service-policy pm_icmp" and test again?
try already but offer rate still exceed.
sh policy-map interface fastEthernet 0/1 output
FastEthernet0/1
      1160179 packets, 1541934600 bytes
      30 second offered rate 1846000 bps, drop rate 683000 bps
      Traffic Shaping
        -      64        3394      4554748   3371      4523882   yes
    Class-map: class-default (match-any)
      97526 packets, 8665938 bytes
      30 second offered rate 3000 bps, drop rate 0 bps
      Match: any
  Policy Map pm_top
    Class cm_icmp
      Traffic Shaping
    Class class-default
What does 'show interface' report?
Does it show more than the target rate?
During burst, it could show a little more than the target rate but the average should reflect equal or less than the target rate.
What platform are you using and IOS code?
in this case a interface traffic report is difficult to check because a traffic flow have a many protocol
for class icmp is match only icmp protocol, i don't khow to verify the shaping rate is true?
because am shape avr is 1mbps but when am show policy-map command the offer rate is more than 1mbps???
How many traffic can send ?
cisco router 2800
ios  c2800nm-adventerprisek9-mz.124-11.T2.bin
Thank you.
The offered rate will provide information on the throughput from the source(s).
In your examples, the source(s) are sending 3.1Mbps and 1.8Mbps respectively.
In your second example, you can see the shaper active and the drop count incrementing.
If you subtract the drop count from the offered rate, you can see it averages down to the shape average value.
This link provides an example of how it's seen during a policer implementation:
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a008010dd6a.shtml
This links provides the command output explanation:
http://www.cisco.com/en/US/docs/ios/12_3/qos/command/reference/qos_s2g.html#wp1146884
"offered rate: Rate, in kbps, of packets coming in to the class."
aoboyle01
what is this Policy statement indicating:
Class-map: NETAPPS (match-all)
      0 packets, 0 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: access-group name NETAPPS
      Traffic Shaping
         40000000/40000000  250000 1000000   1000000   25        125000
        -      0         0         0         0         0         no
Attached Doc is my qos config for an MPLS circuit
It appears to not be working correctly can you help ?
Adrian O'Boyle
