WS-X6708-10GE port showing down/down
imstha001
I have installed WS-X6708-10GE in cisco 6509 Switch and it is recognize by the switch.Now I need to move the connectivity from existing WS-X6704-10GE but seems port does not come up it shows down/down. I am using xenpak in existing interface and X2 in new interface.Please let me know if you have any idea.
2 Accepted Solutions
so here is the problem. The switch is having the SUP card with 3BXL PFC card but the slot 3 is having a 3C based daughter card (DFC). This is why the module is not powering UP. As a quick fix, what you can do is, pull out the card and remove the DFC module from top of the card (only try this if you are aware of the process else the card may get damaged) and reinsert teh card which will just be a CFC based card. This will allow the card to boot up fine.
Or alternatively if you have a different daughter card such as 3B or 3BXL, then add that on module 3 and install it into the chassis.
the existing DFC card will not work with the current SUP card.
Hope this answers your question.
Vinit
PS: Please rate useful posts and mark the question as answered if your query has been resolved.
--Vinit
According to this, the combination should work in 3B mode:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/107258-C6K-PFC-DFC-CFC.html#qa1
The thing is, most likely a reload would be required (I'm guessing the 3C-based card was inserted in the already running 3BXL-based system)...
16 Replies 16
Vinit Jain
Could you please share the below outputs in a file and attach it to this thread:
- show module
- show diagnostic events
- show fab chann
show interface x/y
when you say you are moving the connection, are you moving the connection along with the XFP or just the cable.
Vinit
--Vinit
Hi Vinit,
Thanks for looking into it.
WS-X6708-10GE - power status is showing down
Mod Ports Card Type                              Model              Serial No.
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1104F7RT
  3    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1332VTD6
  5    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL14028CJ4
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAD090601BM
  7   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX    SAL1114KL2T
Mod MAC addresses                       Hw    Fw           Sw           Status
  2  001a.6c68.8560 to 001a.6c68.8563   2.5   12.2(14r)S5  12.2(33)SXI3 Ok
  3  0024.c464.0800 to 0024.c464.0807   2.1   Unknown      Unknown      PwrDown
  5  0026.990b.df58 to 0026.990b.df5b   3.1   12.2(14r)S5  12.2(33)SXI3 Ok
  6  0011.92e7.84ac to 0011.92e7.84af   4.7   8.5(4)       12.2(33)SXI3 Ok
  7  001b.534e.be30 to 001b.534e.be5f   1.5   8.4(1)       12.2(33)SXI3 Ok
06/01 21:40:31.428 E  [6]
test_sp_rp_inband_ping[6]: diag_hit_sp_sys_limit
                             . SP-RP Ping Test skipped. Reason(s): netint_thr_
                             active[1].
06/02 11:18:56.392 E  [6]
                             active[1].
06/11 22:41:01.109 E  [6]
                             active[1].
06/13 06:24:46.688 E  [6]
                             active[1].
06/18 03:26:23.355 E  [6]
                             active[1].
06/20 06:27:52.580 E  [6]
                             active[1].
06/21 07:43:02.173 E  [6]
                             . SP-RP Ping Test skipped. Reason(s): RP CPU is b
                             usy (97% util).
06/23 22:23:19.362 E  [6]
                             usy (97% util).
07/03 16:24:15.156 E  [6]
                             active[1].
07/05 15:12:48.163 E  [6]
                             active[1].
#show fabric channel-counters
 slot channel   rxErrors   txErrors    txDrops  lbusDrops
    2       0          0          0          0          0
    2       1          0          0          0          0
    5       0          0          0          0          0
    5       1          0          0          0          0
    6       0          4          0          0          0
#sh int Ten3/1
TenGigabitEthernet3/1 is down, line protocol is down (notconnect)
  Hardware is C6k 10000Mb 802.3, address is 0024.c464.0800 (bia 0024.c464.0800)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
Switch2.core#
Hi;
Can you share the output of show power?
will you reseat the module on same module or different module?
Thanks & Best regards
#show power
system power redundancy mode = redundant
system power total =     3830.40 Watts (91.20 Amps @ 42V)
system power used =      1246.14 Watts (29.67 Amps @ 42V)
system power available = 2584.26 Watts (61.53 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-4000W-US    3830.40 91.20  OK     OK     on
2    WS-CAC-4000W-US    3795.12 90.36  OK     OK     on
Note: PS2 capacity is limited to 2940.00 Watts (70.00 Amps @ 42V)
      when PS1 is not present
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6148A-GE-TX     105.00  2.50   105.00  2.50  on    on
2    WS-X6704-10GE       295.26  7.03   295.26  7.03  on    on
3    WS-X6708-10GE       444.36 10.58     -     -     on    off (DFC mismatch)
5    WS-X6704-10GE       328.44  7.82   328.44  7.82  on    on
6    WS-SUP720-3BXL      328.44  7.82   328.44  7.82  on    on
7    WS-X6148A-GE-TX     105.00  2.50   105.00  2.50  on    on
8    WS-X6408A-GBIC       84.00  2.00    84.00  2.00  on    on
9    WS-X6408A-GBIC       84.00  2.00     -     -     on    off (Module  Failed SCP dnld)
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   3780.00 Watts (90.00 Amps @ 42V)
system auxiliary connector power limit = 0 Watt
system primary power used =              1246.14 Watts (29.67 Amps @ 42V)
system auxiliary power used =            0 Watt
I have inserted in different slot
It seems like you either do not have enough power on the system or the line card is bad.
Could you please share the below output:
- show env
- show power
the fabric looks good. so it drills down to one of the above scenario's.
Also, check your configuration to ensure that the line card power is not disabled
Vinit
--Vinit
show environment
environmental alarms:
  no alarms
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6K-9SLOT-FAN2
  fan-tray 1 version: 2
  fan-tray 1 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 24C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 26C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 33C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC high
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC high
  power-supply 2 power-output-fail: OK
module 1:
  module 1 power-output-fail: OK
  module 1 outlet temperature: 29C
  module 1 inlet temperature: 27C
module 2:
  module 2 power-output-fail: OK
  module 2 outlet temperature: 41C
  module 2 inlet temperature: 28C
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 41C
  module 5 inlet temperature: 26C
module 6:
  module 6 power-output-fail: OK
  module 6 outlet temperature: 29C
  module 6 inlet temperature: 23C
  module 6 device-1 temperature: 34C
  module 6 device-2 temperature: 34C
  module 6 asic-1 temperature: 23C
  module 6 asic-2 temperature: 24C
  module 6 asic-3 temperature: 23C
  module 6 asic-4 temperature: 24C
  module 6 asic-5 temperature: 24C
  module 6 asic-6 temperature: 24C
  module 6 RP outlet temperature: 27C
  module 6 RP inlet temperature: 28C
  module 6 EARL outlet temperature: 34C
  module 6 EARL inlet temperature: 24C
module 7:
  module 7 power-output-fail: OK
  module 7 outlet temperature: 27C
  module 7 inlet temperature: 26C
module 8:
  module 8 power-output-fail: OK
  module 8 outlet temperature: 26C
  module 8 inlet temperature: 21C
chassis connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 1
  module 1 connector rating: 1092.00 Watts (26.00 Amps @ 42V)
  module 1 power consumption:  105.00 Watts ( 2.50 Amps @ 42V)
module 2
  module 2 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 2 power consumption:  295.26 Watts ( 7.03 Amps @ 42V)
module 3
  module 3 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 3 power consumption:  444.36 Watts (10.58 Amps @ 42V)
module 5
  module 5 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 5 power consumption:  328.44 Watts ( 7.82 Amps @ 42V)
module 6
  module 6 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 6 power consumption:  328.44 Watts ( 7.82 Amps @ 42V)
module 7
  module 7 connector rating: 1092.00 Watts (26.00 Amps @ 42V)
  module 7 power consumption:  105.00 Watts ( 2.50 Amps @ 42V)
module 8
  module 8 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 8 power consumption:   84.00 Watts ( 2.00 Amps @ 42V)
module 9
  module 9 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 9 power consumption:   84.00 Watts ( 2.00 Amps @ 42V)
chassis per slot cooling capacity: 70 cfm
ambient temperature: < 55C
  module 1 cooling requirement: 35 cfm
  module 2 cooling requirement: 70 cfm
  module 3 cooling requirement: 84 cfm
  module 5 cooling requirement: 70 cfm
  module 6 cooling requirement: 35 cfm
  module 7 cooling requirement: 35 cfm
  module 8 cooling requirement: 30 cfm
  module 9 cooling requirement: 30 cfm
#show power
So, based onthe output, it seems you have a mismatch DFC card and the slot 9 is giving SCP dnld failed. Note that you will have to replace the slot 9 (whenever you see SCP dnld failed, replacement is required)
Regarding the mismatch of the DFC, Could you please check which DFC are you using. Hope it is not 3CXL series. The SUP card is 3BXL.
Please share the complete show module output and show inventory output from the switch as it will give us more clarity.
Vinit
--Vinit
#sh module
  1   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX    SAD1107033P
  8    8  8 port 1000mb GBIC Enhanced QoS        WS-X6408A-GBIC     SAL05083ZWE
  9    8  8 port 1000mb GBIC Enhanced QoS        WS-X6408A-GBIC     SAL05073UXH
  1  0019.e829.1340 to 0019.e829.136f   1.5   8.4(1)       12.2(33)SXI3 Ok
  8  0002.7ec1.3bd4 to 0002.7ec1.3bdb   2.0   5.4(2)       12.2(33)SXI3 Ok
  9  0003.3283.5494 to 0003.3283.549b   2.0   5.4(2)       12.2(33)SXI3 PwrDown
Mod  Sub-Module                  Model              Serial       Hw     Status
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1108HF1X  3.1    Ok
  3  Distributed Forwarding Card WS-F6700-DFC3C     SAL1333WCAL  1.4    PwrDown
  5  Centralized Forwarding Card WS-F6700-CFC       SAD1147003H  4.0    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3BXL     SAL1339ZEE9  1.12   Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAD09040EU7  2.11   Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Not Applicable
  5  Pass
  6  Pass
  7  Pass
  8  Pass
  9  Not Applicable
Switch2.core#
Switch2.core#
Switch2.core#
Switch2.core#
Switch2.core#
Switch2.core#
#sh inventory
NAME: "WS-C6509", DESCR: "Cisco Systems Catalyst 6500 9-slot Chassis System"
PID: WS-C6509          ,                     VID:    , SN: SCA050802SM
NAME: "WS-C6000-VTT 1", DESCR: "VTT FRU 1"
PID: WS-C6000-VTT      ,                     VID:    , SN: SMT0502G923
NAME: "WS-C6000-VTT 2", DESCR: "VTT FRU 2"
PID: WS-C6000-VTT      ,                     VID:    , SN: SMT0502K648
NAME: "WS-C6000-VTT 3", DESCR: "VTT FRU 3"
PID: WS-C6000-VTT      ,                     VID:    , SN: SMT0502G029
NAME: "WS-C6000-CL 1", DESCR: "C6K Clock FRU 1"
PID: WS-C6000-CL       ,                     VID:    , SN: SMT0448E069
NAME: "WS-C6000-CL 2", DESCR: "C6K Clock FRU 2"
PID: WS-C6000-CL       ,                     VID:    , SN: SMT0446A062
NAME: "1", DESCR: "WS-X6148A-GE-TX 48-port 10/100/1000 RJ45 EtherModule Rev. 1.5"
PID: WS-X6148A-GE-TX   ,                     VID: V02, SN: SAD1107033P
NAME: "2", DESCR: "WS-X6704-10GE CEF720 4 port 10-Gigabit Ethernet Rev. 2.5"
PID: WS-X6704-10GE     ,                     VID: V02, SN: SAL1104F7RT
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 2", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 3.1"
PID: WS-F6700-CFC      ,                     VID: V04, SN: SAL1108HF1X
NAME: "Transceiver Te2/1", DESCR: "Xenpak Transceiver 10Gbase-CX4 Te2/1"
PID: XENPAK-10GB-CX4   ,                     VID: V01 , SN: EMC10179255
NAME: "Transceiver Te2/2", DESCR: "Xenpak Transceiver 10Gbase-SR Te2/2"
PID: XENPAK-10GB-SR    ,                     VID: V01 , SN: ZZBB0093
NAME: "Transceiver Te2/3", DESCR: "Xenpak Transceiver 10Gbase-LR Te2/3"
PID: XENPAK-10GB-LR+W  ,                     VID: V01 , SN: ZZAF2419
NAME: "Transceiver Te2/4", DESCR: "Transceiver 10Gbase-LRM Te2/4"
PID: XENPAK-10GB-LRM   ,                     VID: V01 , SN: OSG11320310
NAME: "3", DESCR: "WS-X6708-10GE CEF720 8 port 10GE with DFC Rev. 2.1"
PID: WS-X6708-10GE     ,                     VID: V07, SN: SAL1332VTD6
NAME: "5", DESCR: "WS-X6704-10GE CEF720 4 port 10-Gigabit Ethernet Rev. 3.1"
PID: WS-X6704-10GE     ,                     VID: V03, SN: SAL14028CJ4
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 5", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC      ,                     VID: V05, SN: SAD1147003H
NAME: "Transceiver Te5/1", DESCR: "Xenpak Transceiver 10Gbase-SR Te5/1"
PID: XENPAK-10GB-SR    ,                     VID: V01 , SN: IJM1113M0RF
NAME: "6", DESCR: "WS-SUP720-3BXL 2 ports Supervisor Engine 720 Rev. 4.7"
PID: WS-SUP720-3BXL    ,                     VID: V01, SN: SAD090601BM
NAME: "msfc sub-module of 6", DESCR: "WS-SUP720 MSFC3 Daughterboard Rev. 2.11"
PID: WS-SUP720         ,                     VID:    , SN: SAD09040EU7
NAME: "WS-F6K-PFC3BXL Policy Feature Card 3 sub-module of 6", DESCR: "WS-F6K-PFC3BXL Policy Feature Card 3 Rev. 1.12"
PID: WS-F6K-PFC3BXL    ,                     VID: V03, SN: SAL1339ZEE9
NAME: "7", DESCR: "WS-X6148A-GE-TX 48-port 10/100/1000 RJ45 EtherModule Rev. 1.5"
PID: WS-X6148A-GE-TX   ,                     VID: V02, SN: SAL1114KL2T
NAME: "8", DESCR: "WS-X6408A-GBIC 8 port 1000mb GBIC Enhanced QoS Rev. 2.0"
PID: WS-X6408A-GBIC    ,                     VID:    , SN: SAL05083ZWE
NAME: "9", DESCR: "WS-X6408A-GBIC 8 port 1000mb GBIC Enhanced QoS Rev. 2.0"
PID: WS-X6408A-GBIC    ,                     VID:    , SN: SAL05073UXH
NAME: "fan-tray 1", DESCR: "Chassis fan-tray 1"
PID: WS-C6K-9SLOT-FAN2 ,                     VID:    , SN:
NAME: "PS 1 WS-CAC-4000W-US", DESCR: "220v AC power supply, 4000 watt 1"
PID: WS-CAC-4000W-US   ,                     VID:    , SN: SON07271A06
NAME: "PS 2 WS-CAC-4000W-US", DESCR: "220v AC power supply, 4000 watt 2"
PID: WS-CAC-4000W-US   ,                     VID:    , SN: SNI0928BKKD
Vinit
--Vinit
Yes agree to what Lulian mentioned, that might be supported with two impacts - reload + reduced capacity of the LC.
--Vinit
It is working fine with the cisco 6504 with supervisor Engine WS-SUP720-3B.
Here is the output.
##sh module
  1    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAD1142075S
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL09507X76
  3   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL0810VSA2
  4    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1332VTDC
  1  0017.944a.99a8 to 0017.944a.99ab   5.4   8.5(4)       12.2(33)SXJ1 Ok
  2  0016.46e8.34e8 to 0016.46e8.3517   2.3   12.2(14r)S5  12.2(33)SXJ1 Ok
  3  000f.343b.3b88 to 000f.343b.3b97   3.0   7.2(1)       12.2(33)SXJ1 Ok
  4  0024.c464.0860 to 0024.c464.0867   2.1   12.2(18r)S1  12.2(33)SXJ1 Ok
  1  Policy Feature Card 3       WS-F6K-PFC3B       SAD114200J1  2.3    Ok
  1  MSFC3 Daughterboard         WS-SUP720          SAD1142035P  3.0    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAD0951020Z  2.0    Ok
  4  Distributed Forwarding Card WS-F6700-DFC3C     SAL1333WC6X  1.4    Ok
This SUP720 is 3B, the other one was 3BXL - for the router, treating a newly inserted 3C card as 3B is easy, but "downgrading" the whole system from XL mode to non-XL mode requires a reload.
Thanks Vinit for your valuable input. It is working after rebooting the system.
As you mention I might need to add daughter card to enhance the system performance.
