Advice on Cloud OnRamp for Azure with Global VNET Peering
JON SHORTEN
We have a customer looking at SD-WAN with an Azure environment across 3 regions.  Within Azure they are using Global VNet Peering.
When creating the transit network for SD-WAN, do we create 3 x transit networks linked by Global VNet Peering (i.e. 2 x vEdge per region), or treat the peered transit VNet as the onramp (i.e. 2 x vEdge across 3 regions).  If the latter, any advice on vEdge placement would also be welcome.
To add complexity, one of the regions is China, any experience with cross border SD-WAN from China would also be gratefully received.
Lei Tian
Both options are valid. One requires more wan edge licenses than the other, but it optimizes for vNet to onprem traffic flow. I think to have the design fit better for the customer, you need consider other things. Such as, how many vNETs does the customer have? Is there lot cross region vNET to vNET communication? Is the onprem connected over internet or expressroute? How's the on-prem connected to Azure?
Another design option is to use Azure vWAN. It uses Azure hub spoke solution for vNET to vHub, and fully integrated with cisco sdwan solution.
HTH,
Lei Tian
Lei Tian
HTH,
Lei Tian
Hi Lei Tian
Thanks for the reply, at least I know I'm somewhere near the right track.
Do you have any links for Azure WAN - Cisco SD-WAN integration?  IThat may be something this customer would like to look at.
