ā12-09-2024 04:14 AM
I have Cisco C1121 router with version 17.6.6a and i try to bootstrap the router from ciscosdwan.cfg file when i convert it to controller mode using controller-mode enable command but it seems there is problem as you see in the below log
*Dec 9 12:04:58.831: %IOSXE-3-PLATFORM: R0/0: vip-bootstrap: C1121X-8PLTEP-FGL2815L4XT not present in /bootflash/ciscosdwan.cfg, skip loading default config
So i want anyone face the same problem to consult me what can i do?
Kindly check the file of ciscosdwan.cfg in the the file attached?
and what about if i don't want to use the serial number or this type of checkup to make any router to apply this config regardless model and serial number
ā12-10-2024 07:36 AM
Hi @mohammedhesham090 ,
From the error message, i think ciscosdwan.cfg is not present in bootflash. Please doublecheck the file availability in mentioned location.
bash
dir bootflash:
ā12-10-2024 09:14 AM
i check it in the flash and find it and when i issued more flash:ciscosdwan.cfg the router accepts it and display all the contents of it
ā12-10-2024 10:51 AM
can you post the dir output?
check the order of bootstrap
ā12-11-2024 05:32 AM
i found the problem in the yaml language. can you help me to get cisco configuration in yaml language if possible?
ā12-11-2024 06:03 AM - edited ā12-11-2024 06:07 AM
ā01-16-2025 02:04 AM
@mohammedhesham090 , how are you accessing the console of the device?
ā01-08-2025 01:06 AM
Can anyone share how to solve this issue ?
