ciscosdwan.cfg file not working in cisco C1121
I have Cisco C1121 router with version 17.6.6a and i try to bootstrap the router from ciscosdwan.cfg file when i convert it to controller mode using controller-mode enable command but it seems there is problem as you see in the below log
*Dec 9 12:04:58.831: %IOSXE-3-PLATFORM: R0/0: vip-bootstrap: C1121X-8PLTEP-FGL2815L4XT not present in /bootflash/ciscosdwan.cfg, skip loading default config
So i want anyone face the same problem to consult me what can i do?
Kindly check the file of ciscosdwan.cfg in the the file attached?
and what about if i don't want to use the serial number or this type of checkup to make any router to apply this config regardless model and serial number
7 Replies 7
Hi @mohammedhesham090 ,
From the error message, i think ciscosdwan.cfg is not present in bootflash. Please doublecheck the file availability in mentioned location.
bash
dir bootflash:
i check it in the flash and find it and when i issued more flash:ciscosdwan.cfg the router accepts it and display all the contents of it
balaji.bandi
i found the problem in the yaml language. can you help me to get cisco configuration in yaml language if possible?
the router extracted the file successfully but dowsn't take any of the configuration to apply it
@mohammedhesham090 , how are you accessing the console of the device?
allo1zia
Can anyone share how to solve this issue ?
