DMVPN spoke vnet peering to Azure SAP Rise
QW_netzwerk
We have been running DMVPN across all our branches and Headquarters. There are three hub locations under two different WAN connections, and each spoke is connected to those three hubs via NHS clusters. Now, two hub locations also have Site-2-Site VPN to SAP Rise, and very soon, all locations will require connections to SAP Rise. We want to extend our DMVPN into the Azure cloud to deploy one 8000v router as a spoke and create a VNET peer to the SAP Rise. It is essential to point out that the SAP Rise in Azure is currently located in Frankfurt West, and we plan to deploy the Spoke VNET in the same region. Because it will be a new implementation, initially, only two queries come to mind:
  • Can the IP Addresses and NHS cluster priority be configured under the Catalyst 8000v configuration template?
  •  Are there any other considerations we need to take when creating the VNET peering with SAP/RISE?
The Document that is found to connect with SAP RISE:
https://learn.microsoft.com/en-us/azure/sap/workloads/rise-integration-network#virtual-network-peering-with-sap-riseecs
And we what to implement with SAP RISE is:
Virtual network peering with SAP RISE/ECS
It would be great if someone had experienced the same scenario and shared their thoughts and ideas.
I appreciate any help that can be provided.
Cristian Matei
  You can configure NHRP NHS priority on DMVPN for 8000v, as 8000v is the successor of 1000v; as for VNET paring with SAP, just ensure you have functional routing.
Best,
Cristian.
DMVPN is cisco property' I dont think Azure supports dmvpn.
But you can use flexvpn and config hub and spoke.
Azure supports ikev2 flexvpn
MHM
