06-10-2024 11:49 PM
Dear Experts
I have setup SDwan lab setup. So far everything is ok like Vmanage/vBond/Vmsart are up, vEdge are connected and showing up on vManage. What i dont understand is that vBond doesnt show anything in show control connections. I can see DTLS connection on vManage. But why not on vBond? it should be bidirectional like ipsec tunnel right?
06-11-2024 12:12 AM
This is what i am getting from vBond. Everything is in place, but i dont see any connections or history from vBond. I believe we have permanent DTLS connection with vManage/vSmart right?
vBond# show control connections-history
vBond#
vBond#
06-11-2024 12:23 AM
How many vbond yoh have ?
Can I see your topolgy
MHM
06-11-2024 01:19 AM
orchestrator <<- this word need to add to show
Show control connect <- for vedge...
Show orchestrator control <- for vbond
If dont see anything share topology
MHM
06-11-2024 12:12 AM
Do
Show control connection history
Since the dtls tunnel is temporary not permanent between vedge and vbond
MHM
06-11-2024 12:17 AM
vbond only be initial part, once vsmart and vmanage have control connection you do not need vbond, until device reboot and re-establish the connection, its normal behavior.
check onboarding guide :
06-11-2024 01:12 AM - edited 06-11-2024 02:06 AM
You need to use "show orchestrator control-connections history" on the vBond to see the log of onboarded WAN-Edges. As @balaji.bandi mentioned the vBond is only used for orchestration/onboarding of the WAN edges, it doesn't maintain any control connections to other controllers or WAN edge.
I believe the history clears after reboot, which might be why you can't see any vManage connections in the log. Could you make some change to the vBond from vManage(configuration change, add device serials etc.) and check the control connections history afterwards?
