Group deployment is stuck
jdiaz_pratt
I attempted to deploy a change to an existing policy group and the task got stuck in a "scheduled" state for a long period of time. I cleared the stuck task with the API call as detailed here but now the policy deployment is stuck. Any change I attempted to make to the policy or the device attached to it gives me an error about the group deployment being in progress.
Any way to clear the deployment?
jdiaz_pratt
Update: Eventually the task failed with the message "Failed to publish the task on message bus"
I was able to resolve this by restarting the nms components with the following command:
request nms all restart
Their status can be checked with the command
request nms all status
which version of the controller and router do you use? Maybe router does not support policy group based configuration
HTH,
I'm on 20.12.4 Manager and the router is a C8000v 17.12.04. It already had a policy group attached to the device but the issue happened when I was editing the policy group.
I just made a change to a different device (C8200-UCPE running NFVIS 4.12.4) that is managed through the "Network Design" templates and that change is also stuck in a "scheduled" state. Leaving that one alone to see if it eventually goes through or times out and fails.
jdiaz_pratt
