Integration SD-WAN and my existing Billing Support System
maguatte.dieng
Hello Expert ,
i deploying Catalyst Sd-WAN and i need the architecture and design to integration my Sd-wan solution on my existing billing platform. i plan to design my sd-wan offers using my existing billing.
thnaks in advance
AshSe
Hello @maguatte.dieng
Deploying Cisco Catalyst SD-WAN and integrating it with your existing billing platform requires a well-thought-out architecture and design. Below is a high-level guide to help you design and integrate your SD-WAN solution with your billing system.
1. Understand Your Existing Billing Platform
Before designing the integration, you need to analyze your current billing platform:
  • Capabilities: Does it support APIs, custom integrations, or third-party tools?
  • Data Flow: How does it handle customer data, service provisioning, usage tracking, and invoicing?
  • Scalability: Can it handle the additional data and complexity introduced by SD-WAN services?
  • Integration Points: Identify where the SD-WAN solution will interact with the billing platform (e.g., service activation, usage reporting, or customer management).
2. Define Your SD-WAN Service Offerings
Design your SD-WAN service packages based on customer needs and your business model:
  • Service Tiers: Define tiers (e.g., Basic, Advanced, Premium) with varying features such as bandwidth, security, and application optimization.
  • Add-Ons: Include optional services like advanced security, cloud connectivity, or analytics.
  • Pricing Models: Decide on pricing structures (e.g., flat-rate, usage-based, or hybrid).
3. High-Level Architecture
The architecture should include the following components:
a. SD-WAN Components
  • vManage: Centralized management for SD-WAN policies, configurations, and monitoring.
  • vSmart Controllers: Policy and control plane for SD-WAN.
  • vBond Orchestrators: Facilitates secure connections between SD-WAN devices.
  • Edge Devices: Cisco Catalyst SD-WAN routers deployed at customer sites.
b. Billing Platform Integration
  • API Gateway: Acts as a bridge between the SD-WAN solution and the billing platform.
  • Service Orchestration Layer: Automates provisioning, service activation, and updates.
  • Data Collection: Gathers usage data (e.g., bandwidth consumption, application performance) for billing purposes.
c. Network Infrastructure
  • Ensure your existing network infrastructure (e.g., MPLS, internet, LTE) supports SD-WAN deployment.
  • Plan for redundancy and high availability.
4. Integration Design
The integration between Cisco Catalyst SD-WAN and your billing platform can be achieved through APIs and automation tools. Below are the key integration points:
a. Service Provisioning
  • Use APIs from Cisco vManage to automate the provisioning of SD-WAN services.
  • When a customer orders a service, the billing platform triggers the provisioning process via the orchestration layer.
b. Usage Monitoring and Reporting
  • Collect usage data from SD-WAN devices (e.g., bandwidth, application usage) using telemetry or SNMP.
  • Send this data to the billing platform for usage-based billing.
c. Customer Management
  • Synchronize customer data between the billing platform and SD-WAN solution.
  • Ensure that customer profiles, service tiers, and billing information are consistent across both systems.
d. Invoicing and Billing
  • Map SD-WAN service tiers and add-ons to billing items in your platform.
  • Automate invoice generation based on service usage and subscription details.
5. Tools and Technologies
  • Cisco APIs: Use Cisco SD-WAN APIs for integration with your billing platform. Refer to the Cisco DevNet documentation for API details.
  • Orchestration Tools: Consider using tools like Ansible, Terraform, or Cisco NSO (Network Services Orchestrator) for automation.
  • Billing Platform APIs: Ensure your billing platform supports RESTful APIs or other integration methods.
  • Monitoring Tools: Use Cisco vAnalytics or third-party tools for performance and usage monitoring.
6. Security Considerations
  • Data Protection: Ensure customer data and billing information are encrypted during transmission and storage.
  • Access Control: Implement role-based access control (RBAC) for both SD-WAN and billing systems.
  • Compliance: Ensure the solution complies with relevant regulations (e.g., GDPR, PCI DSS).
7. Testing and Validation
  • Test the integration in a lab environment before deploying it in production.
  • Validate the following:
    • Service provisioning and activation.
    • Usage data collection and reporting.
    • Billing accuracy and invoice generation.
    • End-to-end workflows.
8. Deployment and Support
  • Roll out the solution in phases to minimize risks.
  • Provide training for your operations and support teams.
  • Establish a monitoring and troubleshooting process for the integrated solution.
9. Documentation
Document the architecture, integration workflows, and APIs used. This will help with future maintenance and upgrades.
Example Workflow
  1. A customer orders an SD-WAN service through your portal.
  2. The billing platform triggers the provisioning process via the orchestration layer.
  3. Cisco vManage configures the SD-WAN devices and policies.
  4. Usage data is collected from SD-WAN devices and sent to the billing platform.
  5. The billing platform generates an invoice based on the customer's service tier and usage.
By following this approach, you can successfully integrate Cisco Catalyst SD-WAN with your existing billing platform and deliver a seamless experience to your customers.
Hope This Helps!!!
AshSe
Forum Tips:
  1. Insert photos/images inline - don't attach.
  2. Always mark helpful and correct answers, it helps others find what they need.
  3. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
AshSe
9. Documentation
Example Workflow
Hope This Helps!!!
AshSe
Forum Tips:
maguatte.dieng
Hello AshSe
Thanks you for the answer . do you have list if APIs that ca be used for provisionning
