My cEdge CRSv1000 are onboarded to vManage but system ip unreachable
AliDoskii
Hello Folks,
I am labbing SD-WAN on eve-ng.
I am using 3 cEdges, all onboarded into vManage but all of them showed unreachable.
their system ip is not reachable on vManage.
on vSmart when i run show omp peers or routes i cannot see anything but in vBond, i can see all my cEdges in show controller connection.
balaji.bandi
what is the version of all your device you are doing Lab. some version 20.X need to different configuration.
Look at the troubleshooting guide and post the desire output here to understand the issue :
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/214509-troubleshoot-control-connections.html
BB
Praveen Anand
Since you are running on lab, please make sure you have the Root certificates updated on all the devices, make sure that the tunnel interface is enabled on all devices and "Controller Group" under "System Feature Template" is configured.
Please also refer to https://community.cisco.com/t5/sd-wan-and-cloud-networking/sdwan-vbond-not-forwarding-vsmart-addresses-to-cedge/m-p/4067975#M1919
- Praveen Anand
"show control connections" are not vBond command. Better to do troubleshooting beginning from cEdge.
Share output of "show sdwan control connections" and "show sdwan control connections-history" from cEdge. Also, what kind of Controller certifications do you use? Cisco based or enterprise CA?
Meanwhile, check controllers overlay connection as well with "show orchestrator connection" from vBond
HTH,
balaji.bandi
BB
Thanks a lot this was the issue the version i run for edges was not compatible with vmanage , vsmart.
