NAT DIA tracker and two default route
dijix1990
 I bumped into interested problem (don't know is it normal or not)
  1. I have two isp with two default route
  2. I have nat dia (Direct Traffic from Service VPN like ip nat route vrf 16 0.0.0.0 0.0.0.0 global) with track to google (8.8.8.8)
    and today one of my isp did preventive maintenance.
Sla reachability for this isp was timeout but DIA tried to sent traffic via problem providers because def gw was reachable
I thought that if sla has problem traffic not sent to problem link.
19 Replies 19
Enes Simnica
Level 5
Level 5
@dijix1990 this is a normal behavior and happened to me many times. A track object only influences which route is active in the routing table. It does not control NAT or how the router forwards traffic once a route is chosen.
Ur problem ISP's default route likely stayed active in the routing table because its next-hop gateway was still reachable (Layer 2 was up), even though the SLA to 8.8.8.8 via that ISP failed (Layer 3 was broken). Since the route was active, the NAT rule continued to use it.
and here u have a short config to fix it:
track 10 list boolean and
 object 1 (tracks next-hop ISP gateway)
 object 2 (tracks 8.8.8.8)
ip route 0.0.0.0 0.0.0.0 [ISP-Gateway] track 10
SO u track must check both the ISP gateway and the end-to-end path. Use a single tracked object that requires both to be true.
-Enes
CCNP x2 Enterprise
Your Friendly Networking Ninja
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
for legacy I also use it, but for sdwan it can't be usable
balaji.bandi
Can we see more configuration to understand the issue.
BB
M02@rt37
Hello @dijix1990
NAT DiA follows the routing table...and the default route stay up as long as the ISP Gateway is reachable !
So, you need to tie each ISP's default route to a track object driver bye the SLA probe. So, when this probe fails the route will be withdrawn from the RIB and NAT automaticaly switches to your healthy provider.
Best regards
but we can't use next-hop track for transport interface
Static route tracker cannot be configured for VPN 0
Woooooo sorry. I just see that:  !!!  this post is in SD-WAN and Cloud Networking
So sorry .... I think you have the good persons here to help you.
Sorry again.
Best regards
It's not a problem)
MHM
I use DNS Name
MHM
track type is interface the same as in your picture, IP or DNS name doesn't matter because My problem ISP's default route stayed active
MHM
but my track was down when problem was
MHM
