Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
I have question regarding hardware setup for the SD-WAN deployment. Can we setup vManage, vSmart and vBond on the same physical server for production (if resources are sufficient) and redundancy is achieved by lower level like vmware? Any argues against that ?
Hello Lukas,
This is not recommended for production. Imagine the scenario that your physical server is down, so all your controllers will go down with it. While you will try to get the VMs running on another server, you will not manage your network (vManage), bring up more WAN edges (vBond) or even have control plane (vSmart), even thouth WAN Edges will keep working on the last state for a few hours.
Other consideration regarding have more VMs (distributed across multiple servers) is to have proper capacity for your network, Cisco SDWAN is a Scale-Out model so depending on how many WAN edges you have, you need more controllers.
I hope it helps.
Henrique
