SD-WAN vEdge Upgrade path
Jeongjun Park
Hello, team.
Good day.
We are planning to upgrade below platforms to 20.9.x.
Is there any upgrade path ?
- vEdge 5000 20.3.3
- vEdge 2000 20.6.3
- ISR1100-6G (Viptela OS) 20.6.3
Thanks.
based on vedge 20.9 release notes ( https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/vedge-20-9/sd-wan-rel-notes-20-9.html ) which points to below link, we can say that upgrade path for controllers and vedge are the same
However it is interesting why link redirects to controllers 20.5 release note, it should be 20.9:
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/controllers-20-9/rel-notes-controllers-20-9.html#vmanage_upgrade_paths_20_9
Based on above link, direct upgrade is allowed from 20.3 / 20.6
HTH,
HTH,
Thank you for your answer !
I hope you have a good day :_:
balaji.bandi
If you like to upgrade to 20.9.X first you need to upgrade cloud devices  - before you upgrade to edge devices.
BB
Thank you for your answer.
Really appreciate !
