SDWAN QoS
apfeil
EPLAN circuit has 30 different endpoints.
Some have 10G, some have 1G, some have even less.
Is it possible to:
shape traffic from a 10G circuit towards a site with a 1G circuit to 1Gpbs
shape traffic from a 10G circuit towards a site with 10G circuit to 10Gbps
shape traffic from a 10G circuit towards a site with 300Mbps to 300Mpbs.
Alex
per-tunnel QoS can do it:
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/qos/ios-xe-17/qos-book-xe/per-tunnel-qos.html
Supported only in hub&spoke topology, and this is not "per site", but "per tunnel". If remote sites (spokes) have only one transport, so you can assume it as per site as well
HTH,
