vEdge not displayed in vManage
OddievenInc
vEdge not listed under WAN Edge in Vmanage. When checked the running-config from vManage > Configuration > Devices following error is shown. It was shown previously.
Device data error
[vmanagedb] No system ip found for uuid (Chassis Number)
Can ssh to the vEdge, and the control connections are showing as UP.
What could be the issue.
have you tried clearing control connections? Be careful, if it is production.
HTH,
HTH,
inderdeeps
Level 4
Level 4
@OddievenInc : Did you check the certificate and check if vEdge is in the Valid state ?
It may possible the vEdge is in invalid state or in staging.
