vManage unable to talk to devices after poweron
bmcgahan
I'm running vManage 20.9.4.1 in EVE-NG, and every time I power-on my virtual topology, the vManage doesn't work after it boots.
DTLS tunnels do form from vManage to the vSmart/vBond and Edge Routers, but vManage can't actually send any commands to them. The attached error is what I get when I try to view the Running Config from vManage of any device. It looks like it can't connect via NETCONF
I've tried clearing the control-connections, restarting the nms services on the vManage, but the only thing that works is a reload.
I don't understand why a reboot is needed, vs. vManage just powering on in the first place. Has anyone seen this issue before, and is there any workaround other than a reload?
TIA!
balaji.bandi
i run same setup - i do not see any issue,
my boot order vbond and vsmart- then vmanage.
what device IP you showing error on screenshot ?
BB
10 Replies 10
Cedge# show control local-properties
Check the serial number of cedge before and after power-on/off
Also check cert. Validate
MHM
Good idea, but I checked and the chassis/serial numbers stay the same between booting the instances, and the certificates are valid.
balaji.bandi
BB
In the screenshot above, that IP is the vSmart, but I get the same error if I try to send commands to any of the Edge Routers as well. What's strange is that the vManage shows 100% health to all devices:
show control connections looks good from the vManage also:
From vManage if I goto Configuration > Devices , then click the 3 dots on the right of any device and choose Running Configuration it hangs for a minute then returns this:
Device data error
jave.io.IOException: Unable to connect to vmanage-admin@172.17.1.1:830
the error is different than your original post? the IP is different
MHM
It's for every IP in the PEER SYSTEM IP list in show control connections.
 try this without adjust delay
Show sdwan peer <- in cedge
Do you see vbond connection OK
MHM
I added a 60 second delay for vBond to boot, and 120 second delay for vManage. I think this sorted the problem out for now. Thanks for the suggestion!
Rajeev Sharma
Could you try clearing control connections on the others instead, i mean vSmart, vBond and cEgde?
HTH.
Yes, thanks, I tried that. The DTLS tunnels re-establish after a few seconds, but vManage still gets the same error when sending commands to any Device.  Also there are no errors in show control connections-history on any of the controllers or edges.
