06-17-2024 07:37 AM - edited 06-17-2024 11:19 PM
I have two cedge router and I have configured VRRP in the service VPN (VRF 1) but the VRRP state of two router is master. I have pasted the configuration in below.
Router1:
interface Vlan101
vrf forwarding 1
ip address 10.1.1.2 255.255.255.0
no ip redirects
ip tcp adjust-mss 1430
vrrp 101 address-family ipv4
priority 105
vrrpv2
address 10.1.1.1 primary
exit-vrrp
arp timeout 1200
Router2:
interface Vlan101
vrf forwarding 1
ip address 10.1.1.3 255.255.255.0
no ip redirects
priority 90
vrrpv2
exit-vrrp
arp timeout 1200
in Below you can see the result of show vrrp brief command:
Router1: show vrrp brief
Interface Grp A-F Pri Time Own Pre State Master addr/Group addr
Vl101 101 IPv4 105 0 N Y MASTER 10.1.1.2(local) 10.1.1.1
Router2: show vrrp brief
Vl101 101 IPv4 90 0 N Y MASTER 10.1.1.3(local) 10.1.1.1
Please help me to solve this problem
Solved! Go to Solution.
06-18-2024 11:39 PM
I found the problem. Behind these two routers is an old non-Cisco switch. I deactivated the 'Unknown Multicast No Flood' feature in this switch, and the problem has been solved.
06-17-2024 11:49 AM
Hi Hamidreza,
Do you have connectivity between both VLANs?
How do you interconnect both routers, do you have a Core switch?
06-17-2024 11:51 AM
Maybe, It could be a typo, but you are showing us Vlan1 configuration, but on the sh vrrp br you hace Vlan101 as active on both WAN Edge.
06-18-2024 01:00 AM
I rectified that. Thanks
06-17-2024 11:16 PM
Yes, I can ping the physical IP address from each router to the other router.
06-17-2024 02:44 PM
1. Can router1 and router2 communicate each other? ICMP?
2. Is multicast between routers permitted?
06-18-2024 12:54 AM
Yes, I can ping , the ICMP goes between the two router.
There is an old (non-Cisco) switch between the two routers. I have doubts that the old switch does not support protocol 112 or Multicast. I must more investigate about these unknown old switches
06-18-2024 02:06 AM
Have you tried pinging 224.0.0.18?
06-18-2024 02:43 AM
show vrrp <<- can I see this from cedge
also can I see
show interface trunk <<- from C9K
and
show vlan brief <<- from C9K
MHM
06-18-2024 11:39 PM
