Meddane
If you are using Umbrella/OpenDNS solution, you can use the following links to test your configuration:
http://welcome.opendns.com https://welcome.umbrella.com/
Test if Security setting is blocking for Phishing:
http://www.internetbadguys.com
Test if Security Setting is blocking for Malware:
http://www.examplemalwaredomain.com
Test if Security Setting is blocking for Command and Control Callback:
http://www.examplebotnetdomain.com
Test if IP Layer Enforcement is blocking blacklisted IPs:
http://ipblock.opendnstest.com/
Test if the Intelligent Proxy works:
http://proxy.opendnstest.com
Test if SSL Decryption works:
https://ssl-proxy.opendnstest.com
Test if SSL decryption with file inspection works:
https://ssl-proxy.opendnstest.com/download/eicar.com
Test if SSL decryption with file inspection blocks the download of malware using AV engine:
http://www.eicar.org/download/eicar.comhttps://www.eicar.org/download/eicar.com
Please rate if it is beneficial for you.
Redouane
1 Comment
Cloudberry
Yes this is pretty neat, thank you! I would love to display a customized block page for the 'Newly Seen Domain' security category which would tell the client that this is blocked due to this category and that it is usually accessible within 72 hours.
