LSA4
Level 3
Level 3
Hi Team
Can Cisco ISE help with the below?
The proposed solution should be scalable to support more than 1million network-connected devices and manage Layer 2/ Layer 3 devices in non-dot1x mode
2.Proposed solution should support uninterrupted, out-of-band (with all features and functionality) to ensure that the network keeps running, even if the solution goes down for any reason.
3.Proposed solution should be able to support/integrate with various manufacturers of network switches (such as Cisco, HP/Aruba, Alcatel, Juniper, Arista, Huawei, Brocade /Foundry, etc.) without making any changes to the existing configuration or requiring upgrade to these infrastructure elements.
4.Proposed solution should be deployed without requiring 802.1X for access control functions
5.Proposed solution should not require agent/client endpoints to obtain profiles, check posture against the default, or to have access to the full features/functions of the NAC solution (for managed devices). The agent can be used for AD-managed Windows devices.
6.The proposed solution should support device tracking (what it is, where it is, who it is, when, and how it connected)
7.The proposed solution should be able to identify IOT devices such as: IP cameras, VOIP, projectors, HVAC devices, etc.
8.The proposed solution should provide Indicators of Compromise (IOC) to discover and mitigate threats from infected endpoints
9.The solution should support two-way information sharing and workflow automation with security technologies such as advanced threat detection (ATD), vulnerability assessment (VA), enterprise mobility management (EMM), state-of-the-art firewalls, device protection platforms (EPP), and security event aggregation (SIEM) systems
