Catalyst 3560 telnet error - need help
over7volt
I have a Catalyst 3560 and when trying to assign IPs to a port (using telnet to the switch's main IP) I keep getting an error.
Here is the commands as s I am trying to enter them and you can see the error I have highlighted in red below.
SC-153>enable
Password:
SC-153#config t
Enter configuration commands, one per line.  End with CNTL/Z.
SC-153(config)# interface FastEthernet0/23
SC-153(config-if)#IP Address xx.xx.xx.xx 255.255.255.248 Secondary (NOTE: IP  substituted with "xx")
% Invalid input detected at '^' marker.
SC-153(config-if)#
All  I'm  trying to do is bind a /29 ip block to port #23
Will someone please tell mee WHY I'm ting  what appears to be a syntex errror  or what ever kind of error it is
Thanks for any help
5 Replies 5
Leo Laohoo
It keeps getting an error because you did not enable IP routing.
conf t
ip routing
int f0/23
no switchport
ip address 1.1.1.1 255.255.255.0
no shut
end
Thanks for yoru quick reply.
So the commands I need to enter would be?
SC-153>enable
Password:
SC-153#config t
SC-153(config)# no switchport
Is that correct?
You need to be in interface mode to issue command no switchport
so
SC-153>enable
Password:
SC-153#config t
SC-153(config-if)no switchort
than
SC-153(config-if)no sh
Where's your command to enable routing??
Hi Guys,
Thanks for your help.
I got the ips routed to the correct port thanks to a Linux engineer I know.
I need a good tutorial on the bare basics for the most common telnet tasks. Something with  examples since I'm completely new to this.
Thanks again
