Cisco 3020 Blade Switch gecrashed
askodikara
One of our Blade switches has crashed, error log as follows,
*Mar  1 05:31:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan550, changed state to up
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: System previously crashed with the following message:
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Cisco IOS Software, CBS30X0 Software (CBS30X0-LANBASE-M), Version 12.2(25)SEF1, RELEASE SOFTWARE (fc3)
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Copyright (c) 1986-2006 by Cisco Systems, Inc.
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Compiled Tue 23-May-06 15:26 by antonino
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Program Exception (0x0700)!
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: SRR0 = 0x003C38AC  SRR1 = 0x00029210  SRR2 = 0x00451BDC  SRR3 = 0x00021200
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: ESR = 0x08000000  DEAR = 0x00000000  TSR = 0x84000000  DBSR = 0x00000000
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: CPU Register Context:
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Vector = 0x00000700  PC = 0x003C38AC  MSR = 0x00029210  CR = 0x20000008
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: LR = 0x003C38A4  CTR = 0x0027C814  XER = 0x60000020
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: R0 = 0x003C38A4  R1 = 0x014D6650  R2 = 0x00000000  R3 = 0x00000004
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: R4 = 0x013A1E60  R5 = 0x00000001  R6 = 0x00433EDC  R7 = 0x00000004
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: R8 = 0x00029210  R9 = 0x00000002  R10 = 0x01220000  R11 = 0x00F60000
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: R12 = 0x0070D567  R13 = 0x00110000  R14 = 0x00000002  R15 = 0x00000000
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: R16 = 0x00000000  R17 = 0x00000000  R18 = 0x01220000  R19 = 0x01220000
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: R20 = 0x00F0CF5C  R21 = 0x012D27D0  R22 = 0x01220000  R23 = 0x0187F530
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: R24 = 0x00000000  R25 = 0x0004073F  R26 = 0x01220000  R27 = 0xEF180E50
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: R28 = 0xEF19007A  R29 = 0x00000000  R30 = 0x01220000  R31 = 0x00000000
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Stack trace:
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: PC = 0x003C38AC, SP = 0x014D6650
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 00: SP = 0x014D6678    PC = 0x003C38A4
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 01: SP = 0x014D6680    PC = 0x003C3964
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 02: SP = 0x014D66A0    PC = 0x004B97AC
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 03: SP = 0x0126264C    PC = 0x00451060
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 04: SP = 0x0126265C    PC = 0x00451008
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 05: SP = 0x0126267C    PC = 0x0045342C
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 06: SP = 0x01262684    PC = 0x004538F8
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 07: SP = 0x012626D0    PC = 0x00451110
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 08: SP = 0x0187F298    PC = 0x0000D3CC
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 09: SP = 0x0187F2A0    PC = 0x002659D8
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 10: SP = 0x0187F4D0    PC = 0x00423870
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 11: SP = 0x0187F4E8    PC = 0x00AAF21C
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 12: SP = 0x0187F528    PC = 0x006C9400
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 13: SP = 0x0187F5F8    PC = 0x006C8E04
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 14: SP = 0x0187F610    PC = 0x006C8A64
.Dec 26 22:21:20: %PLATFORM-1-CRASHED: Frame 15: SP = 0x0187F638    PC = 0x006C848C
Dec 27 09:10:14: %SYS-5-CONFIG_I: Configured from console by vty0 (172.22.25.22)
Please help to fixed this issue,
Asa,
6 Replies 6
Leo Laohoo
Wow.  That's one very, very, very OLD IOS.
If there are any crashinfo file(s), can you please post the latest three files?
Thanks for the update.
I'll attach the crashinfo files ASAP
regards,
Asa
As you request, I have attached the crashed info.
Asa.
Signal = 4, Vector = 0x700
Thank you very much for the output.  They were very helpful.
Here's the story, the blade has been crashing because of the error "Signal = 4".  I have never seen something like this so the only thing I can tell you is that this is a code that simply means "Illegal Opcode Exception".  It could mean that you are running an old IOS and you're hitting a bug.
You can contact Cisco TAC and get them to analyze the crashinfo files.  You can put this thread into the TAC Case so you don't need to repeat your story all over again.
Thanks for the prompt update.
If you can give me a hint to select an IOS it would be much appreciate.
No I won't.  You select the IOS version of your choice and read the Release Notes before making your decision.
