(CiscoASR1002-X) Cause of increasing frame item in input error
tggam
Below is the product information I use.
1. System: CiscoASR1002-X
2. NIC: SPA-1X10GE-L-V2
3. OS Ver: XE 3.10.1S
The input error increased as shown below, increased in the frame item. May I know when this item is incremented?
TenGigabitEthernet0/2/0 is up, line protocol is up
Hardware is SPA-1X10GE-L-V2, address is 84b8.0248.c020 (bia 84b8.0248.c020)
Description: To MVNO10G_IPS#B1
MTU 1550 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive not supported
Full Duplex, 10000Mbps, link type is force-up, media type is 10GBase-SR/SW
output flow-control is on, input flow-control is on
Last input 00:00:14, output 00:01:46, output hang never
Last clearing of "show interface" counters 11:32:27
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 12000 bits/sec, 21 packets/sec
5 minute output rate 12000 bits/sec, 21 packets/sec
2197988976 packets input, 2495541501382 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
3618 input errors, 0 CRC, 3618 frame, 0 overrun, 0 ignored
0 watchdog, 69 multicast, 0 pause input
1027908141 packets output, 333403157788 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Leo Laohoo
Not helpful.
balaji.bandi
what device connected other side :
you also have input errors here :
have you changed teh MTU ?
my suggestions :
1. check the Physical cable.
2. check other side MTU
3. check any speed mismatch,
4. check the logs both the ends
some troubleshoot tips :
https://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1904.html
BB
