Nexus 5548UP link down Problem
fhgsit
Frequent Visitor
Frequent Visitor
we have a Nexus 5548UP with a trunk Port, Port is configured identical to some working connection, it has the following config:
interface Ethernet1/1
description icarus
switchport mode trunk
switchport trunk native vlan 145
switchport trunk allowed vlan 145,152
swi-rhb-server1# show int eth1/1 transceiver details
Ethernet1/1
transceiver is present
type is 10Gbase-SR
name is CISCO-OEM
part number is SFP-10GB-SR
revision is B4
serial number is OE50012225
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM2 fiber is 82 m
Link length supported for 62.5/125um fiber is 26 m
Link length supported for 50/125um OM3 fiber is 300 m
cisco id is --
cisco extended id number is 4
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 29.04 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.26 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 7.05 mA 15.00 mA 1.00 mA 12.00 mA 2.00 mA
Tx Power -1.58 dBm 0.79 dBm -7.98 dBm 0.00 dBm -7.01 dBm
Rx Power N/A -- 3.01 dBm -16.02 dBm 0.00 dBm -13.01 dBm
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
the port is connected to a dell server with broadcom 57414 25g nic, in this nic is a cisco-compatible 10gb sfp+
the server thinks the port is up, nexus says its down, however, we are able to tcpdump packets coming from nexus over the "down" link. I dont know how to force it up now, t should already work. Vlans are running
thanks for any hint.
No worries glad all good and working, appriciated your feedback.
BB
balaji.bandi
if this is 25G nic, can work with 10G compatable, then try no autonegition on Cisco side (# no negotiate auto). ( also if the config allow set the port speed 10GB on dell side)
can you post show interface eth 1/1
BB
thanks for your time, and sorry for your time, its solved, my personal layer 8 Problem 😕
BB
