Server Networking
Cisco UCS X-Series Energy Efficiency Offer
i have a project to design a data center purely web hosting. i need advice on what factors i should consider and which cisco platforms best fits for scalability, performance for web servicesmy thinking1. for FW should I use pix or asa?which is better...
raysm by Level 1
  • 1086 Views
  • 3 replies
Hi,I’m looking to practice Cisco ACI. Is it possible to run ACI at home using EVE-NG? If not, are there any affordable online rack rental options available for Cisco ACI labs?Thanks in advance!
samoa683 by Level 1
  • 2537 Views
  • 2 replies
  • 1 Helpful votes
Hello,I have two of the NVIDIA DGX V100s. They're the same specs as the standard PCIe & SXM2 V100s, except they have DisplayPort output (which I don't need and won't be using). I like my C240 M4s, so I picked up a used C240 M5 because it supports the...
Hello,I found documentation discrepancy about the ports speed capability of the Nexus 9348GC-FXP.The datasheet from Cisco is : https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-742284.html This datash...
