01-24-2015 07:50 PM
i am doing a firmware autoinstall stuck at 94%. any idea what is happening? I do not see any pending activities.
01-25-2015 02:56 AM
From which version to which version was the upgrade done ?
It seems, that the slave FI was done, and you ack'd to go ahead with the slave (subordinate) FI ?
Can you please post the firmware information of the FI's
Also output of "show cluster sta..."
01-25-2015 08:24 AM
01-25-2015 08:53 AM
The infrastructure upgrade (UCSM, IOM and FI) looks perfect to me; cluster is also perfect. It might be a cosmetic bug ? or the cleanup didn't finish properly.
01-25-2015 09:25 AM
on the subordinate:
show cluster state
Cluster Id: 0xea47020a0db511e4-0xb742002a6aca0284
A: UP, SUBORDINATE
B: UP, PRIMARY
INTERNAL NETWORK INTERFACES:
eth1, UP
eth2, DOWN
HA READY
eth2 shows down.
and on the primary
show cluster state
B: UP, PRIMARY
A: UP, SUBORDINATE
eth1, UP
eth2, DOWN
HA READY
eth2 shows down?
is this the problem?
01-25-2015 10:03 AM
Maybe ! It is definitely a problem, you have a single point of failure
Was this working before the upgrade ?
Is the heartbeat a direct connection (cable) ?
What is the distance in between ?
Or was a port failing during the upgrade ?
01-25-2015 02:21 PM
its a new setup so I dont know. I know the cluster ports are all connected. L1 to L1 and L2 to L2
but why is eth2 showing down? I have link lights on both
