Force interface UP/UP in Nexus 9000
We are trying to get a Nexus port (which is a span destination for Rx) to be up and transmit even if Rx is not connected in it.
In other cisco platforms you could achieve this by using the no keepalive command but seems to be taken out in the N9K platform.
Thanks!
Sergiu.Daniluk
You can do that for SVIs using "no autostate", but you do not have an option to bring up a physical port if no RX power is received on it.
Stay safe,
Sergiu
