Help needed to spec kit for a DC
moorepl
Hi Guys,
I'm hoping you can help me out. I'm trying to satisfy some DC requirements for a client for a new build they are planning. They have given me the following requirements:
Top Of Rack
1)             Fixed configuration 1 Rack Unit (RU) Form factor
2)             48 IEEE 802.3x full duplex on 100BASE-TX, and 1000BASE-T ports
3)             32 1Gbps or 10Gbps/FCoE ports
4)             Backplane capacity of a minimum of 40Gbps and a maximum of 80Gbps
5)             Internal Redundant Power Supplies
6)             Virtualisation of the data plane at layer 2
7)             Vlans
8)             IEEE 802.1Q VLAN encapsulation
9)             IEEE 802.1s MSTP
10)          IEEE 802.1w RSTP
11)          IEEE 802.3ad Link Aggregation
End Of Rack
1)             Fixed configuration Form factor
2)             Support for 1Gbps and 10Gbps Ethernet access
3)             Support for Fibre Channel and Fibre Channel over Ethernet access
4)             High Availability support for top of rack switching
7)             Vlans
9)             IEEE 802.1s MSTP
12)          NTP
13)          AAA
14)          SYSLOG
15)          TFTP/FTP
16)          SNMPv2 and SNMPv3
17)          SSH
18)          IEEE 802.1s MSTP
19)          IEEE 802.1w RSTP
20)          IEEE 802.1p Classification
21)          Congestion Management Features
22)          Congestion Avoidance Features
23)          Traffic Shaping Features
24)          Traffic Policing Features
Is there a 1RU switch that fits the requirements for all the above ?. I was planning on going dwn the 4948 series route but I was not aware of one that gave 10gb ethernet access. Unless I go down the 4507R+E and use the new 12 port 10GB cards, but the requirements are asking for 32 1 or 10gb ethernet access. Also, I've never configured a switch for FCOE, as it was always only our SAN guys that did that. I know Nexxus will support 10gb, but they are not considered top of rack are they ?
Any help you can give is greatly appreciated guys.
Mooey
Chad Peterson
Hi Mooey,
If you are going to need FCoE, then Nexus 5000/5500 will be likely what you'd want to go with.  When combining it with the various Nexus 2000 FEX modules I think this should satisfy most of the requirements.  The 2224T and 2248T will allow 48 100/1000 ports.  The 2232P provides 32 1/10gb ports using SFP/SFP+.
Take a look at the data sheet here to look at all the SKUs to see which would fit:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps10110/data_sheet_c78-507093.html
However you won't find 1 RU sku here that will provide 100/1000gb and 10gig connectivity to hosts.  You'll have to choose here and design the rack with that in mind.
Also, we do have a 4948 that does have 10gig uplinks, WS-C4948-10GE.  However it doesn't do FCoE:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps6230/product_data_sheet0900aecd80246552.html
Take a look over it, hope it helps out
Chad
