Load balancing with Serial Leased Lines & Etherdrops
bvsnarayana03
Level 5
Level 5
This problem is a unique one.
I have 6 Internet Leased Lines of 2 Mbps each. Keeping in view of the increasing thirst for Bandwidth, I ordered Etherdrops for the ease of on the fly upgrade, as & when needed.
To my surprise, when these Etherdrops were terminated on router, there was no trafic flowing over these etherlinks. I had to forcefully put traffic on these links using PBR.
I want to use all my links i.e. 6 serial + 2 etherlinks for per packet load-balancing.
can some1 help.
spremkumar
Level 9
Level 9
are you running any routing protocols with your ISP ?
also you can have a max of 6 equal cost route in routers.
Thats the reason i feel you are unable to use the etherdrops.
Y dont u think off going on upgrading the E1s into Fiber and take them as single ethernet output or a E3 output ?
regds
Thanks Prem.
This could be the reason.
I've default routes pointing to each of the E1 interfaces (6 int).
For time being, I'm evaluating link load-balancer for this purpose. & yes will be converting those serial to etherdrops.
