ā01-05-2011 02:06 AM
Hi, we have on former working VEM which does not come online in VSM after reboot of VEM-ESX. Its VEM Module 5
SW3-LINZ-XDE5# sh svs connections
connection vcenter:
ip address: 22.161.70.237
remote port: 80
protocol: vmware-vim https
certificate: default
datacenter name: NW-VIRT
DVS uuid: ef 03 0b 50 af 04 16 1f-9a de 58 49 54 35 9d d0
config status: Enabled
operational status: Connected
sync status: Complete
version: VMware vCenter Server 4.1.0 Build-258902
!# VSM hear from Module 5
SW3-LINZ-XDE5# sh svs neighbors
Active Domain ID: 1
AIPC Interface MAC: 0050-568b-6cca
Inband Interface MAC: 0050-568b-3a4c
Src MAC Type Domain-id Node-id Last learnt (Sec. ago)
0050-568b-13f7 VSM 1 0201 605520.16
0002-3d40-0103 VEM 1 0402 664779.10
0002-3d40-0104 VEM 1 0502 862.74
0002-3d40-0105 VEM 1 0602 1957112.55
0002-3d40-0106 VEM 1 0702 1712752.86
SW3-LINZ-XDE5#
!# but module 5 does not appear in VSM
SW3-LINZ-XDE5# sh module
Mod Ports Module-Type Model Status
1 0 Virtual Supervisor Module Nexus1000V active *
2 0 Virtual Supervisor Module Nexus1000V ha-standby
4 248 Virtual Ethernet Module NA ok
6 248 Virtual Ethernet Module NA ok
Mod Sw Hw
1 4.0(4)SV1(3b) 0.0
2 4.0(4)SV1(3b) 0.0
4 4.0(4)SV1(3b) 2.0
6 4.0(4)SV1(3b) 2.0
Mod MAC-Address(es) Serial-Num
1 00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8 NA
2 00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8 NA
4 02-00-0c-00-04-00 to 02-00-0c-00-04-80 NA
6 02-00-0c-00-06-00 to 02-00-0c-00-06-80 NA
Mod Server-IP Server-UUID Server-Name
1 22.161.70.233 NA NA
2 22.161.70.233 NA NA
4 22.161.70.34 001529b8-f87a-df11-8ae0-0022bdd7a96c 22.161.70.34
6 22.161.70.33 2023dbeb-7a67-df11-b476-8843e1c2d268 22.161.70.33
* this terminal session
SW3-LINZ-XDE5#
!# strange is that on VEM the
vem-health check 0050-568b-6cca
!# shows that VEM, VSM conectivity seems ok
!# also with
vem status -v
!# we see that module is loaded and uplinks are present
!# I also can see that the uplinkports are up with
vemcmd show port
!# the only differnce to other working VEMs we can see with
vemcmd show card
!# there the "Heartbeat set : False" on working VEMs this value is true.
!# MAC-Adresses of VEM and VSM are seen on the phys Uplink-switches as well on the correct ports in the correct vlans
Also a additional reboot of the ESX does not help
But the Module does not come up !!!
Any Idea about this problem
btw
Nexus 1000 V : 4.0(4)SV1(3b)
VEM: 4.0.4.1.3.2.0-2.0.1
Thx in Advance
Hubert
ā01-05-2011 05:22 AM
You are following the correct steps for troubleshooting the problem. If the MAC addresses are being seen on the VSM, VEM, and upstream switches than connectivity should work. The only thing left to check is to see if the VEM module is actually seeing the heartbeat messages. You can use vempkt on the VEM to see if you are getting heartbeat messages.
One other thing to try is to remove the ESX host from the N1KV in vCenter and add it back. I have seen times where vCenter doesn't always send all the right data to the host on the initial install.
If all the above fails, please open a TAC case. It might be a bug or some configuration issue having to do with your environment.
louis
ā01-06-2011 03:37 PM
Hey All,
Just in regards to the above posting. If the VEM is not seeing the right data you can validate this by running "vemcmd show card" this will validate if the vemis programmed correctly i.e. domain id etc.
ā01-06-2011 10:53 PM
@ Andrew, thx, I know, but we already doublechecked this
ā01-06-2011 10:52 PM
Yeah, I am going to open a SR
