10-16-2010 03:34 PM
Hi all,
I have the attached topology. All the conf outputs and device details are attached. The problem is "vemcmd show card info" output shows that VEM correctly receives the control, packet VLAN information from the VSM. However I couldnt make vempda service to run. I got the same output all the sayins that : "VEM Agent (vemdpa) is not running". I checked the control and packet vlan end to end connectivity by creating VMs and etc. there werent any problems....One thing is that, VEM AIPC MAC never showed up in the upstream switch which is connected to ESX host.
I would be glad if someone can help me out with any configuration errors or anything like that...
[root@sahaesx1 ~]# vem status -v
Package vssnet-esx5.5.0-00000-release
Version 4.0.4.1.3.0.0-2.0.21
Build 21
Date Sat May 22 16:25:36 PDT 2010
Number of PassThru NICs are 0
VEM modules are loaded
Switch Name Num Ports Used Ports Configured Ports MTU Uplinks
vSwitch0 128 4 128 1500 vmnic0
DVS Name Num Ports Used Ports Configured Ports MTU Uplinks
vsm1yeni 256 51 256 1500 vmnic2,vmnic1
[root@sahaesx1 ~]# vemcmd show version
VEM Version: 4.0.4.1.3.0.0-2.0.21
VSM Version: 4.0(4)SV1(3)
System Version: VMware ESX 4.1.0 Releasebuild-235786
[root@sahaesx1 ~]#
Solved! Go to Solution.
10-18-2010 06:02 AM
You still need an uplink port-profile on a VSM running on the 1010. You cannot attach a VEM to a 1010 directly. It needs to attach to a VSM running on the 1010. Once you have a VSM installed on the 1010 its the exact same installation as if you were installing a VSM on ESX. You need uplink and veth port-profiles and the first uplink must carry the control and packet vlans.
The process I use to get N1KV installed on an ESX host is to choose a free nic and add the nic to the uplink that carries the control and packet vlans. The NIC you add to the N1KV is the NIC that is used to carry control traffic. We will not use a nic attached to a vSwitch to push control traffic. The NIC must be on the N1KV.
So if you add vmnic1 to the vDS, vmnic1 is pushing the control traffic. Once the VSM sees the ESX host you can add the other nics and start migrating traffic over the N1KV.
louis
10-18-2010 05:19 AM
There are no uplink port-profiles defined in your VSM config. When you add an ESX host to the N1KV what uplink are you choosing? There needs to be an uplink with the control and packet vlans at a minimum defined.
Check out the getting started guide at http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_0_4_s_v_1_3/getting_started/configuration/guide/n1000v_gsg.html
And there is a N1KV specific site with lots of information at https://www.myciscocommunity.com/community/products/nexus1000v
louis
10-18-2010 05:31 AM
Hi Iwatta,
We upgraded the ESX version to the required version level and VMPDA service starts running.
This is a Nexus1010 setup though. I do not think that I still need to setup port profiles for system vlans. System vlans are configured on Nexus 1010 and VSM seperately.
port-profile type ethernet Unused_Or_Quarantine_Uplink
description Port-group created for Nexus1000V internal usage. Do not use.
vmware port-group
shutdown
state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
vmware port-group
shutdown
state enabled
My exact question is, if I do have vmnic 0 bind to vswif0 on ESX, and when I add the host to VSM , I associate the vmnic1 and vmnic 2 to vDS (I will use vmnic0 with the regular vswif. At this exact point, on which vmnics should the control and packet vlans be configured already ? on vmnic 1 and 2 only , or vmnic 0 only or all of them ?
10-18-2010 06:02 AM
louis
10-18-2010 06:10 AM
Hi Iwatta,
Thanks for responding.
Control VLAN is : 444
Packet VLAN is : 445
I added the following config on VSM :
"port-profile type ethernet system-uplink
switchport mode trunk
switchport trunk allowed vlan all
no shutdown
system vlan 444-445
state enabled"
Port 1 -2 carries the management and control traffic, Ports 3-6 carries the data traffic on NExus 1010.
Would this be a correct setup ?
10-18-2010 06:35 AM
Ok. Now VEM and VSM speaks to each other. However I can not see VEM on "show module vem mapping" ? Is there any specific reason to that ?
[root@iacm-1 tmp]# vem-health check 00:02:3d:70:01:03
VSM Control MAC address: 00:02:3d:70:01:03
Control VLAN: 444
DPA MAC: 00:02:3d:40:02:00
The VEM-VSM connectivity seems to be fine.
vsm1yeni# show module uptime
------ Module 1 -----
Module Start Time: Thu Oct 14 16:49:45 2010
Up Time: 3 day(s), 23 hour(s), 45 minute(s), 6 second(s)
vsm1yeni# show module vem mapping
Mod Status UUID License Status
vsm1yeni# show module vem counters
Mod InNR OutMI InMI OutHBeats InHBeats InAipcMsgs OutTO OutTOC InsCnt RemCnt
vsm1yeni#
10-20-2010 07:28 AM
The Nexus 1010 was using 4.0.4.SV1.3. As soon as we upgraded it to 4.0.4.SV1.3a all problems solved.
Thanks.
Dumlu
