10-08-2010 02:41 PM
i have a server with a qlogic CNA card connected to the nexus 5k.. The physical ethernet port seems to come up but the vfc interface refuses to come up
I have tried many suggestions like cconfiguring the interface as trunk, making sure the fcoe vlan is allowed on the trunk etc but still the vfc interface doesnt come up
the relevant configurations are attached ...
I also tried to disable fcoe negotiation mode using the command fcoe mode on but this command seems to be unavailable under the interface though feature fcoe has been enabled
version 4.1(3)N2(1)
feature fcoe
feature telnet
feature interface-vlan
feature fex
role name default-role
description This is a system defined role and applies to all users.
rule 5 permit show feature environment
rule 4 permit show feature hardware
rule 3 permit show feature module
rule 2 permit show feature snmp
rule 1 permit show feature system
no password strength-check
ip host N5K 10.10.10.10
hostname N5K
snmp-server enable traps entity fru
vrf context management
ip route 0.0.0.0/0 10.10.10.1
vlan 1
vlan 201
fcoe
vsan database
vsan 201
interface Vlan1
no shutdown
interface Vlan201
no shutdown
interface Vlan300
interface vfc9
bind interface Ethernet1/9
no shutdown
interface vfc10
bind interface Ethernet1/10
no shutdown
vsan database
vsan 201 interface vfc9
vsan 201 interface vfc10
vsan 201 interface fc2/1
vsan 201 interface fc2/2
vsan 201 interface fc2/3
feature npv
npv enable
npv auto-load-balance disruptive
interface fc2/1
no shutdown
interface fc2/2
no shutdown
interface fc2/3
no shutdown
interface fc2/4
no shutdown
interface fc2/5
interface fc2/6
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
switchport mode trunk
switchport trunk allowed vlan 1,201
spanning-tree port type edge trunk
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface mgmt0
ip address 10.10.10.10/24
line console
boot kickstart bootflash:/n5000-uk9-kickstart.4.1.3.N2.1.bin
boot system bootflash:/n5000-uk9.4.1.3.N2.1.bin
cfs ipv4 distribute
interface fc2/1
switchport mode F
interface fc2/2
switchport mode F
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
any ideas ??
Ambi
10-08-2010 06:52 PM
Is feature LLDP enabled? You need that for the CNA to discover the FCOE vlan, and a Storage Protocols Services License. Please post "show lldp nei" and "show npv flog" and let's see what that shows.
Do you have storage targets in fc2/1 - 3 or an upstream SAN switch? If SAN switch is upstream, then VLAN 201 needs to match your upstream VSAN on fc2/1-3, and the ports are configured a F port, they should be NP.
Also if you upgrade to 4.2 you could setup a san-port-channel to your upstream SAN switch (NP-F or TNP-TF), which I think is a better solution than disruptive load balancing, but may need a MDS on the other end.
Is this connects both your host and your storage target, then maybe you need fabric mode (FC switch) instead of NPV mode, for your zoning as well.
Please rate helpful posts.
10-09-2010 03:32 AM
yes the switch will be connected to both the storage and the servers
can you let me know how to enable fabric mode on the switch
In the mean time i will enable lldp and try to post the outputs
Ambi
10-09-2010 04:51 PM
I don't recall exactly, but it seems like you can't have targets connected in NPV mode. You need a switch to handle the fabric logins ("show flogi dat").
You can run the 5K as a FC switch with "no feature npv" or the default out of the box. Backup your config as it might delete it. Going from a FC switch to NPV mode deletes the config and forces a reboot, and the reverse might do the same. You should verify all this as we run the 5K in NPV mode and connect them upstream to MDS.
10-21-2010 11:29 AM
Have you gotten this working? I have a very similar problem and opened a new thread as to not hijack this one-
Cheers!
10-22-2010 01:55 AM
Yes .. the issue was the twin-ax cable connecting the Dell servers and the N5K
We replaced the same with a fiber cable and it worked fine
Ambi
