NEXUS 2232TM and Nexus 5010P
ahmed.abdraboh
HI ALL,
does Nexus 2232TM can work as a FEX for N5010P?
if so can we also use FET to connect the above two switches?
Ahmed
Prashanth Krishnappa
Yes to both..As long as you are running minimum required NX-OS of 5.0(3)N2(1) and later
thank you
