09-16-2008 12:41 PM
Do the integrated 10 GigabitEthernet interfaces on the Nexus 5000 and the interfaces on the 32-port 10 GigabitEthernet linecard for the Nexus 7000 support GigabitEthernet connectivity also or just 10Gig? If not, how do I uplink GigabitEthernet ports directly to the Nexus 7000 over fiber?
Thanks in advance!
09-22-2008 04:02 PM
I would also like to know the answer to this question. Any help would be greatly appreciated.
11-06-2008 07:27 PM
We will have a 48-port 1G fiber module available for the Nexus 7000 very soon, December 2008 or so.
On the Nexus 5020 you can connect GE servers to the first 16 ports.
Hope this helps.
Please rate.
Brad
11-07-2008 09:25 AM
Our Cisco rep recently told us the same thing. Thanks for the reply.
11-07-2008 10:17 AM
11-10-2008 05:32 PM
According to Cisco, 1G support is not available until December.
11-11-2008 12:03 PM
Can you buy
Cisco Nexus 7000 Series 48-Port 10/100/1000 Ethernet Module with 40 Gbps Fabric
N7K-M148GT-11 ?
Is it available ?
11-11-2008 06:46 PM
Yes, the N7K-M248GT-11 module with RJ45 copper interfaces has been available since Nexus 7000 was made available early this year.
It is the SFP version of that module supporting fiber interfaces that will be available very soon.
Hope this clarifies.
-Brad
12-19-2008 07:22 AM
Yes the 5010 can connect on the first 8 ports at 1 gig and the 5020 can use the first 16 ports.
The 7k has a 68 port sfp based blade that allows 1 gig..
-C
