Nexus 5048P with HP FLex-10
hello,
we have two HP Flex-10 module in c7000 chassis connected to the HP Storag array with HP SAN Switch and two nexus 5048P.
me question is about the configuration between flex-10 and nexus 5K,is using vPC and trunk link to the flex-10 will be enough, i find some configuration example in the internet talk about vsan and zonning concept ,so if we use hp san switch it will be no storage configuration in the nexus ?
here an example of configuration that i find :
Configuring Port-channel linked to Virtual-Connect
Configuration needs to be done on both switches
interface port-channel12
description ** VC to HPBS Bay 1 **
switchport mode trunk
switchport trunk allowed vlan 1-2,220, 222, 250, 270
vpc 12
spanning-tree port type edge trunk
interface port-channel13
description ** VC to HPBS Bay 2 **
vpc 13
interface Ethernet1/13
description ** Po12 member to HPBS **
channel-group 12 mode active
interface Ethernet1/14
description ** Po13 member to HPBS **
channel-group 13 mode active
thanks.
krun_shah
You only need to configure any fiber channel related command if you are using it as a FCF like below.
If you are using HP san switch for fiber channel connectivity you do not need to configure nexus 5548 for fiber channel.
krun_shah
thanks for replay,that clear my idea.
