11-06-2019 03:05 AM - edited 11-06-2019 03:08 AM
Hi, we´re using two Nexus 5596s with VPC as Distribution Layer Switches - And 2960s as Access Layer switches - which is working Perfectly fine. Besides the fact that we are running out of Ports on the nexus swtiches. But as a solution we bought 2 Nexus 2232P Fex modules. We are planning to install them redundantly to both switches (I already prepared the config which I will post below). The only thing im asking myself right now is - how do i configure a redundant uplink for a Catalyst 2960x. Do I simply need to configure a Portchannel or do I need a VPC aswell when the Fex Modules are both connected to both Nexus switches? Config (will be applied on both Nexus switches) :
interface port-channel3 description downstream.sw-di-203/204_FEX switchport switchport mode fex-fabric fex associate 100 no shut interface eth1/47 switchport switchport mode fex-fabric fex associate 100 channel-group 3 no shut exit fex 100 description upstream.sw-di-203/204 interface port-channel4 description downstream.sw-di-203/204_FEX switchport switchport mode fex-fabric fex associate 101 no shut interface eth1/48 switchport switchport mode fex-fabric fex associate 101 channel-group 4 no shut exit fex 101 description upstream.sw-di-203/204
11-06-2019 04:53 AM
As per my understanding, you already have set up running nexus and cat 2960 switch.
If you like to add new FEX, they connect to nexus 5K,( there is no Dual homed, then your config works as expected)
If they are dual-homed like FEx connected to 5K1 and 5K2 -then you need to add vpc config to port- channel.
I have not understood this statement? if you thinking to connect to 2960 to both 5K you mean, Port-channel at 2960 end, vPC at nexus side.
11-06-2019 04:59 AM - edited 11-06-2019 05:00 AM
Thanks for the Reply. In the meantime I have come so far to know that I want a "Active/Active FEX with Enhanced vPC" (see: https://community.cisco.com/t5/server-networking/difference-between-vpc-and-enhanced-vpc/m-p/2450401/highlight/false#M9055 )
The only thing that I need to know is if it is possible to connect more 2960s switches to the Fex modules with a Port-Channel (vpc?). I only ever see clients connectected to those. See Picture in Post I linked above.
11-07-2019 11:52 AM
As i have provided the information, FEX to extend the network in DC environment. for the End Device to Connect like servers.
If you like Cat 2960 connect into the network, suggest and recommend to connect to Nexus 5K rather to FEX ? does this answer your question?
11-07-2019 10:07 PM
Unfortunately I do not have enough ports on the Nexus itself to attach 6 more Stacks of 2960s
11-08-2019 12:34 AM
To be honest, I have not tried it
i understand your restrictions and limitation of ports
2 options :
Options1 :
Migrate any server can move to FEX
Options2 :
You can try that is risk connecting Switch to FEX (i do not recommend)
(why risk is by default FEX port set a Portfast).
