- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
on 03-06-2012 08:01 AM
- Introduction
- Access models
- Using Control Polices
- Address assignment options
- Applying configuration to a subscriber
- Quality of Service
- Multicast and video distribution
- Call Admission Control
- AAA
- Subscriber Services
- Redundancy and fan out
- Wholesale Models
- High Scale Deployment Best Practices
- Related Information
Introduction
Broadband deployments are complex because of the options you have, varying needs in terms of deployments, the combination of technologies and many other reasons. In this article we'll go over the various designs, options and service deliverables that you can achieve with the ASR9000 BNG solution.
Access models
One of the decissions to be made when running BNG is the type of access that is preferred. There are 2 key options for the ASR9000 which is PPPoE (PPP over Ethernet) or IP sessions. Both can run on single or double tagged subinterfaces.
PPPoE sessions are triggered by the reception of a PADI and IP sessions are created by using DHCP as a session trigger.
In XR4.2.1 we can also use the "packet trigger" which means that an unclassified L3 address can be used to start a new session.
Also one has to decide on the Access interface, whether that is a single physical interface or access via bundles with multiple members. When choosing bundles the next decission is whether the members run in an active/active mode (that is all members are forwarding traffic) or in an active standby mode (whereby there is one link not forwarding traffic and only taking over when one of the member(s) fails).
Bundles vs Phyiscal interfaces
In the ASR9000 the use of a phyiscal interface, whether that be a GigabitEthernet or a TenGigabitEthernet interface are terminated on the linecard, this significantly increases the scale as effectively every linecard becomes its own controller of the sessions.
When you are running bundles, the sessions are then maintained on the RSP.
The LC's currently have their own Control Policy Engine, PPP manager and AAA processes. But they lack IGMP and LI today. This means that if you are planning to use LI or IGMP or parameterized QOS LC based subscribers should not be the choice for you.
You can use bundle interfaces with one member and disabling LACP to pull the subs to the RSP so that you have access to these features:
interface GigabitEthernet0/0/0/0
bundle id 100 mode on
When you are using bundle interfaces, all features enabled on the subscriber are programmed to the NP's where the bundle has members on.
So running a bundle with 2 members effectively creates the subscriber on both NPU's for those members, because of the phenomenal failover support it has.
For downstream loadbalancing we can use destination based hashing, which is the subscriber's ip address, so we always hash the traffic from one subscriber over 1 member, but the subscribers would be spread over the members based on their destination address.
The following configuration takes care of that:
interface Bundle-Ether100
bundle load-balancing hash dst-ip
When one member fails, the traffic is carried over to the other member seemlessly.
For the upstream direction, we can't control how the traffic arrives to us, which is controlled by the access layer device, whether that be your metro device or DSLAM.
Linecard based subscribers
This is an XR 5.1.1 deliverable. LC subs will increase the scale even further as it distributed the control plane to the LC as opposed to the RSP.
Hardware requirements
The hardware you require for BNG on the ASR9000 is:
- Any typhoon linecard such as the A9K-MOD80-SE, A9K-24x10, 36x10 and MOD160.
- A9K-RSP440-SE
Note that for both the RSP and the linecard we need to have the "SE" or Service Edge variant.
Also the ASR9001 will support BNG.
Trident linecards are not supported for subscriber termination, but they can be used as core facing linecard for transport
The MOD80 is a 2NP based linecard. Per NP we support 32k sessions with 64k per linecard.
Per Port we support up to 8K sessions when they are running QOS. This because of the QOS architecture within the NP that won't allow more then 8k parent shapers per phyiscal port. (that restriction is partially lifted in XR4.3.1 which allows for QOS chunk allocation more dynamically. You still have 32k parent shapers, but you can instruct a subinterface to use a chunk. This means a limitation of 8k per vlan, 32k per NPU)
These retrictions apply regardless of whether you are using LC or RSP based subscribers.
All linecards that run BNG need to be of the Typhoon kind (NP4). Your core facing interfaces if not running BNG can be Trident based or SIP700 based. However if you are using L2TP, then your core facing LC's need to be NP4 also. This is because the L2TP decap is not implemented in SIP or Trident which is handled by the core facing LC in the downstream direction.
Radius Source Ports
Each LC is assigned a source port range for radius, so while all LC's present themselves as a single NAS-ID, the source ports they are using effectively identify the node within the system. This is transparent for your use and nothing needs to be configured for that.
However it is imperative that your radius server supports extended source-ports (so the combination of source-port + radius-request-ID) defines a unique request. This is the same in IOS otherwise you can only support a call window of 256 (as the radius ID is only an 8 bit field). So check your radius-server capability!
For example see this radius request received on a radius-server:
Tue Apr 5 16:55:45 2011: [17224] message received from 3.0.0.234/49080.12 code=4, length=361
Tue Apr 5 16:55:45 2011: [17224] Acct-Interim-Interval = 60
Tue Apr 5 16:55:45 2011: [17224] Acct-Status-Type = Stop
Tue Apr 5 16:55:45 2011: [17224] Cisco-avpair = "if-handle=167774432"
Tue Apr 5 16:55:45 2011: [17224] Cisco-avpair = "client-mac-address=0010.9441.0001"
Tue Apr 5 16:55:45 2011: [17224] Acct-Session-Id = "00000054“
This radius (accounting) request was sent from UDP Port 49080 and its radiusID is number 12
You can check in LPTS in IOS-XR where that source port is mapping to:
RP/0/RSP1/CPU0:A9K-BNG#show lpts pifib hardware entry br location 0/1/CPU0 | i 49080
Tue Apr 5 17:22:52.941 EST
(VRF:0) any.49080 , any.any UDP any 48 deliver 48
If you decode 48 into binary: 48 =======> 0 0 0 0 1 1 0 0 0 0 (Binary of 48)
The "1" represent the RSP's in the middle slot of a 10 slot chassis!
PPPoE vs DHCP/IP-sessions
Broadband access has natively been using PPP based access, which originates from the dial days, whereby modems dialing into a modem-bank/access server allowing the transmission of data packets by encapsulating them in PPP packets. When access evolved to higher speeds using DSL (effectively ATM over the phone line), PPP was still used in the flavor of PPPoA (PPP over ATM).
Now that the aggregation point's uplinks are transitioning from ATM based to Ethernet based and the fact that there is Ethernet directly to the home, PPPoE has made a strong hold in the access layer.
Still with DSL in the first mile, DSLAM's may convert the PPPoA session into PPPoE towards the aggregator leaving PPP with a (well deserved) strong precense in the access.
In a transition to an all ethernet, there is no need per-se to run PPP at the access. PPPoE requires a client (which nowadays come natively in many operating systems however), which created the opportunity for a more simple approach of direct IP access using DHCP as a signal to trigger the session creation.
Drrivers of PPPoE are:
- Ability to run multistack, each Layer 3 protocol is negotiated separately via their CP (Control Protocol) during the NCP phase (Network Control Protocol)
- Authentication natively build in via protocols such as CHAP, PAP, MS-CHAP etc
- Link control (~negotiable options during LCP)
- Keepalives
- Ability to aggregate multiple lines together into a single link such via MLP (Multilink PPP)
IP sessions don't have an authentication natively build in as there is no concept of username/password here, but with BNG deployments there are options now by having the BNG construct a username out of options of the DHCP discover or other fields such as MAC address, access interface, VLAN etc.
First Sign of Life comparison between PPPoE and IPoE sessions
Access Interfaces
This is the basic configuration to be setup in order to get PPPoE and IP sessions running.
Note that PPP and IPoE sessions can co-exist on the same parent interface as well as on the same subinterface.
This this is a base configuration example to setup the FSOL handling for PPPoE or IP sessions.
Using ambigious vlans
Originally for double tagged traffic, also known is QinQ or QiQ, we had to explicitly configure the inner and outer vlan combination for each possible termination point. In ASR9000/XR we can define ambigious ranges allowing us to specify the outer vlan only and an inner range.
The most common deployment scenario for QIQ is whereby the outer vlan represents the dslam and the inner vlan represents the subscriber, obviously configuring 64k subinterfaces is not very easy to manage and the Ambigious vlan support greatly reduces operational overhead, large configs and provides for much more simplicity:
Configuration example:
interface Bundle-Ether1.50
service-policy type control subscriber PPP_IP_PM1
pppoe enable bba-group default
encapsulation ambiguous dot1q { any | <vlan range> }
dot1ad { any | <vlan range> }
dot1q <vlan#> second-dot1q { any | <vlan range> }
dot1ad <vlan#> second-dot1q { any | <vlan range> }
DHCP/IP sessions
PPP sessions have a native keepalive build in. If keepalives are not sent between the BNG and the client, the sessions are automatically torn down. IP sessions don't have a native keepalive mechanism and some implementations opted for an ICMP or ARP keepalive methodology to detect absent IP sessions as opposed to relying on (potentially long) DHCP lease timers.
ASR9000 does not have ICMP or ARP keepalives for IP sessions rather instead we have a different mechanism of lease-proxy which is elaborated on in this section.
Restart handling
Problem domain 1:
IPoE sessions are initiated upon receipt of a DHCP discover and can be terminated prior client’s IP address lease expires/is released by:
- CoA Account-Logoff/PoD
- Session Administratively cleared
- Reload
Need a way to recreate session if client lease is still valid:
Once we have marked the Binding in the dhcp proxy on the BNG as "stale" due to one of the reasons mentioned above, a subsequent DHCP request from the client (eg on renew) is NAK'd to the client who will then faill back to a discovery mode upon which we can recreate the session.
To support a sort of keepalive mechanism we can shorten the lease time, which will require the session to renew its lease at half the lease time. So we effectively have a keepalive mechanism at half-lease time in this scenario.
This inherently increases the load on the dhcp server because the BNG will forward the renew requests to the dhcp server and when Acknowledged it will maintain the binding and the session.
A smoother solution is the concept of "lease proxy". This means that eventhough the server offers a lease, in this example of 40 minutes, the BNG advertises a lease to the client of a configurable time, in this example 10 minutes.
Every 5 minute interval the client will renew, but now the BNG intercepts and re-acknowledges the lease to the client, as opposed to relying on the dhcp server to ack the renew.
At half the lease time, here 20 minutes, we renew with the dhcp server to maintain proper state.
DHCP lease limits
Lease limit and Lease proxy for DHCP subscribers
Lease limit for a given proxy profile can be specified for:
per remote id:
eg.,
dhcp ipv4
profile dhcp-red proxy
limit lease per-remote-id 1000
per circuit-id:
eg.,
dhcp ipv4
profile dhcp-green proxy
limit lease per-circuit-id 1000
or
per interface:
eg.,
dhcp ipv4
profile dhcp-blue proxy
limit lease per-interface 1000
Note that per circuit-id and per remote-id options are confined to any given access
interface. In other words, per circuit id limit on a given access interfaces doesn't affect
or influence the circuit-id limit configured for any other access interface
Lease proxy:
DHCP lease proxy is also known as DHCP split lease. With this implementation, the DHCP proxy
ie., BNG router will renew the lease of the client without contacting the DHCP server. The
lease proxy value configured is assumed to be lower than the server lease. Following terminologies
are used:
i) Client<->Proxy is the client lease
ii) Proxy<->Server is the proxy lease
ASR9K is the DHCP proxy
Lease proxy benefits include:
a) shorter client lease times and longer proxy lease
b) Proxy can respond faster to renews at the network edge
c) Reduces load on centralized DHCP servers for renewal processing
Configuration:
dhcp ipv4
RP/0/RSP0/CPU0:BNG1(config-dhcpv4-proxy-profile)#lease proxy client-lease-time ?
<300-4294967295> Value of lease proxy client-time in seconds
dhcp ipv4
lease proxy client-lease-time 300
Example TAL (Transparent Autologon) use case 1
TAL or transparent autologon is one of the most commonly used access scenarios for IP sessions.
You can authenticate the user on mac address or option 82 information. The following use cases depict on how to set that up with the ASR9000 BNG implementation.
Example TAL use case 2
IP sessions and security forwarding
When your access interface is configured for IP it by nature can start forwarding IP already. A session that takes a static source ip can start forwarding traffic just fine then.
This could be a security issue and this has been done at the explicit request from some our initial adopters of A9K BNG.
Downstream traffic can only flow on AMBIGUOUS vlans when we have a session since the mapping from destination IP to mac and vlan is only held by the dhcp binding. In UNAMB scenarios, we could technically send traffic down to the sub.
UPstream traffic can be mitigated by either using:
- uRPF
- ACL
ACL being a far less pps implication then uRPF.
also uRPF will not necessarily capture all issues, especially when an ip source is chosen in the same range as the unnumbered or designated address of this access interface.
When you apply an ACL, make sure it allows DHCP to go through.
Packet trigger or unclassified Source
This implementation allows for IPoE subscribers to be established based on
a received packet from an IP source on the access interface when the "unclassified
source" is enabled. Typically, the sessions will be restricted to packets originating
from a particular network. Multiple matching criteria may be specified to match packets
from discontiguous networks. In addition, the packets may be subject to radius based
AAA for a successful session bringup. An access interface may be configured to support
both DHCP and PKT triggered sessions
In an ideal network, the subscriber would first send an ARP request to the access
interface and if the packet matching criteria are met, this in itself is a sufficient
condition to bringup the IPoE session. However, if there is a burst of traffic with
unique flows, this could overwhelm the BNG router in terms of processing each packet
to determine if it is a IPoE (PKT) candidate. The software limits the amount of in-flight
requests to 200. In cases where traffic rates for IPoE-PKT sessions are high (>120 pps) and
there are also parallel DHCP based sessions creates in progress, it may be desirable to
configure static policer on the line cards. Based on testing results, a policer rate of
200 per LC is shown to handle this stress condition satisfactorily.
Configuration:
RP/0/RSP0/CPU0:BNG1#config
Wed Jun 13 14:20:40.883 PDT
RP/0/RSP0/CPU0:BNG1(config)#lpts punt police location 0/0/cpu0 protocol unclassified rsp rate 200
aaa attribute format ip-plus-mac
format-string length 253 "%s:%s" addr client-mac-address
interface Bundle-Ether10.41
ipv4 address 21.1.1.1 255.255.255.0
service-policy type control subscriber ipsub_policy1
encapsulation dot1q 30
ipsubscriber ipv4 l2-connected
initiator dhcp
initiator unclassified-source
policy-map type control subscriber ipsub_policy1
event session-start match-first
class type control subscriber class-dhcp do-all
1 activate dynamic-template ipsub_template
3 authorize aaa list default identifier circuit-id password dhcp123
5 activate dynamic-template acct-default
class type control subscriber class-pkt do-until-failure
3 authorize aaa list default format ip-plus-mac password abc123
end-policy-map
class-map type control subscriber match-any class-pkt
match source-address ipv4 192.1.0.0 255.255.0.0
end-class-map
dynamic-template
type ipsubscriber ipsub_template
ipv4 unnumbered Loopback1
One integral part of the BNG solution in XR is the use of control policies.
With control policies you are able to manage the sessions life while various events on the session are triggered.
You can handle these events or ignore them depending on your configuration and deployment needs.
User authentication/control
One key action in the control policy is obviously the authentication.
These can be executed via the command under the event/class:
- 10 authorize aaa list default identifier source-address-mac password cisco
- 10 authenticate aaa list default
Both of these will trigger a RADIUS access-request message, but the difference between the two is with the authorize statement we can compose the username ourselves regardless of what is received on the line, where as the authenticate statement uses the PPP chap or pap username and password received. The authenticate option for that reason only applies to PPP based sessions.
You can define the username in the authorize statement either inline as per example above or you can construct the username via a "formatted" way:
Note that an authentication does NOT have to succeed in order for BNG to bring up the session.
The activation of a dynamic template will create the subscriber interface regardless of the authentication result.
A failed authentication will result in an unauthenticated state and you'll be able to apply HTTP-redirect or restricted access on the session.
Nas identification
Source IP
Is by default selected of the interface's address that is used to reach the radius-server.
This is configurable to be overriden from this default.
RP/0/RSP0/CPU0:A9K-BNG(config)#radius source-interface <interface name>
Or per default configuration:
RP/0/RSP0/CPU0:A9K-BNG#show run | i radius-server
Fri Mar 16 12:40:15.791 EDT
Building configuration...
radius-server host 3.0.0.38 auth-port 1645 acct-port 1646
radius-server attribute list LIST
RP/0/RSP0/CPU0:A9K-BNG#sh route 3.0.0.38
Routing entry for 3.0.0.0/8
Known via "connected", distance 0, metric 0 (connected)
Installed Feb 22 15:42:37.812 for 3w1d
Routing Descriptor Blocks
directly connected, via MgmtEth0/RSP0/CPU0/0
Route metric is 0
No advertising protos.
RP/0/RSP0/CPU0:A9K-BNG#sh run int mgmtEth 0/rsP0/CPU0/0
Fri Mar 16 12:40:26.121 EDT
interface MgmtEth0/RSP0/CPU0/0
ipv4 address 3.0.0.233 255.0.0.0
RADIUS:
Thu Mar 15 11:55:12 2012: [18848] NAS-IP-Address = 3.0.0.233
Nas-Port-ID
Attribute 87 can be filled with the configuration like this:
aaa attribute format NAS-PORT-ID
circuit-id plus remote-id
aaa radius attribute nas-port-id format NAS-PORT-ID
Nas-ID
Attribute 32 is the BNG's hostname, always and only configurable when changing the router's hostname.
Example:
RP/0/RSP0/CPU0:A9K-BNG#sh run | i host
hostname A9K-BNG
RADIUS:
Thu Mar 15 11:55:12 2012: [18848] NAS-Identifier = "A9K-BNG"
Nas-PORT
Attribute 5
Is computed very flexibly configured on a per session type basis:
aaa radius attribute nas-port format e <format> [type <0-44>]
Format (32bits): entered as a string of letters:
Zero : 0
One : 1
Slot : S
Adapter : A
Port : P
(Outer) VLAN Id : V
Session-Id : U
Inner VLAN ID: Q
Ex “SSSSAAPPPPPVVVVVVVVVVVVVVVVVVVVV”
Type
ETHERNET 15
PPPOEOE 32
PPPOEOVLAN 33
PPPOEOQINQ 34
VIRTUAL_PPPOEOE 35
VIRTUAL_PPPOEOVLAN 36
VIRTUAL_PPPOEOQINQ 37
If type is omitted it will apply and be used for any session without a more specific type definition.
Control policy Events, Classes and Actions
The folllowing pictures shows how everything ties together in a control policy:
The diagram below shows where the various events would be triggered for a PPPoE session.
Note that the session activate event is only applicable to PPP sessions.
You need to make sure that the session-start event has a template defined with the lcp paramters
which are used during LCP.
the power of the solution, amongst many others, is the differentiation you can do between authentication failures as well as no response,
so you can act upon a faulty username differently then a radius-server not responding.
Failover for that reason can be embedded in the control policy like this:
event session-activate match-first
class type control subscriber CLASS do-until-failure
10 activate dynamic-template TPL
20 authenticate aaa list default
event authentication-failure
class ...
10 "apply http redirect"
On authentication failure we an apply a layer 4 redirect service while keeping the session active.
event authentication-no-response
10 authenticate aaa list failover-list
If there was no response from radius, we can try a different radius-server list
Using Class-Maps
The class map definition allows you to control how the event triggered is handled.
Either the event is handled for the first class that is matched, or ALL classes for this event are evaluated as part of the event definition directive.
Example:
class-map type control subscriber match-any IP_SUB
match protocol dhcpv4
! The above would match specifically on IP subscribers only
class-map type control subscriber match-any PPP_SUB
match protocol ppp
! This example would match specifically on PPP subscribers only
Using these example classes allows you to have a single control policy that can handle events and use different actions per access category.
Available Match Criteria:
- Domain name: domain <string>
- Protocol: protocol { dhcpv4 | ppp }
- Source address: source-address { ipv4 | mac }
- User name: username <string>
- Authentication Status: authen-status { authenticated | unauthenticated }
- To negate match criteria: not <>
Available Match policies (as part of the class-map definition):
- match-any: match any of match clauses
- match-all: match all match clauses
If you only have 1 match clause in your class-map it obviously doesn't make a difference whether you choose match-all or match-any.
Also the class-maps allow for very extensive control of the event handling whereby you can handle a particular event differently for an unauthenticated ppp subscriber vs an authenticated ip subscriber or any combination of that of course!
Handling failed authentications
When an authentication fails for a subscriber against radius, we can still bring the user up by activating a dynamic template.
So the order of actions executed during an event is very important along with using do-until-success/failure etc.
For instance the following actions:
event session-start do-all
20 authorize aaa list default mac-address password cisco
would bring up the subscriber even with failed authentication.
In this example where the actions are effectively reversed:
event session-start do-until-failure
10 authorize aaa list default mac-address password cisco
20 activate dynamic-template TPL
would not bring up a user after authentication failure.
Alternatively, you can pull in the event for authorization failure and disconnect the service like this:
event authorization-failure do-all
10 disconnect
Or you can use the authorization failure to apply HTTP-Redirect and start a timer, so effectively allowing the user to login within that time before he is getting disconnected.
Account Logon
If the user failed authentication and has a restricted access service applied, we can force the user to go the web portal to provide credentials and try to login again, pay their bill etc.
The model is here that the user goes to a web page to provide credentials that are then send via a coa account logon to the BNG.
The BNG will generate an access request to authenticate using these credentials.
If it succeeds new attributes can be send in that access-accept to remove the restricted access or HTTP-R service.
How IP sessions /DHCP interact with AAA
Obviously in order for a subscriber to have access to the network, an address has to be handed out. There are different options available for this that'll be listed out here.
Local pools (PPPoE)
When you have PPPoE based sessions, the easiest implementation is to define a local pool from which the addresses are handed out to the subscriber during IPCP
The associated configuration is:
pool vrf default ipv4 POOL
address-range 199.1.1.1 199.1.255.255
Multiple ranges can be provided and addresses in that range can be excluded.
Which can be monitored via this command:
RP/0/RSP0/CPU0:A9K-BNG#show pool ipv4
Allocation Summary
Used: 1
Excl: 0
Free: 65278
Total: 65279
Utilization: 0%
Pool VRF Used Excl Free Total
POOL default 1 0 65278 65279
The Pool can either be referenced directly on the dynamic template which is activated to the subscriber during its event handling in the control policy like this:
This is the template that holds the base configuration for subscribers when this template gets activated on the session:
dynamic-template
type ppp TPL
ppp authentication chap
ppp ipcp dns 1.2.3.4 1.2.3.3
ppp ipcp peer-address pool POOL
ipv4 unnumbered Loopback1000
This template can then be referenced in an event handling of the control policy as with this example:
policy-map type control subscriber sub
Alternatively the POOL can also be referenced via Radius Attributes during the Access-Accept as per following example:
- With a Cisco-Avpair
user1@domain.com Password = "cisco"
Service-Type = Framed-User,
Framed-Protocol = PPP,
Cisco-avpair = "ipv4:addr-pool=POOL",
- Using an Ascend Attribute (number 218):
Ascend-Assign-IP-Pool = POOL
- Using an IETF Attribute (number 88):
Framed-Pool = POOL
- Alternatively, but uncontrolled is the use of the Framed-IP-Address magic number 255.255.255.254 which will instruct the NAS to do a "pool pick" from any pool available.
Using this method of locally defined pools on the BNG is by far preferred because it allows us to create a summary route and advertise the pool in its whole. This reduces significant amount of routing updates, but has the limitation that a full block is assigned to the BNG regardless of whether it needs it or not.
Pool advertisement
Can be done via the following methodology:
First define a summary route for the pool range:
router static
address-family ipv4 unicast
199.1.0.0/16 Null0
Next inject that summary route into your eg IGP via a redistribution command
router ospf CORE
redistribute static
When users come online they will have a /32 in the routing table which is then followed for forwarding rather then the summary route to NULL0.
Another "disadvantage" of this methodology is that you'll be drawing all 199.1.x.x traffic to the BNG regardless of whether there is a session or not. However the ingress LC's NPU will drop the packets in hardware in that case.
Radius based pools (PPPoE)
Instead of assigning a pool on the BNG, you can also outsource the pool management to a radius-server.
IT is recommended to have the radius server select a pool per BNG device, this in order to keep the model of summary advertisement.
If the pool attributes are distributed between different BNG's, you're required to inject the /32's which will put unnecessary burden on your IGP.
In this case you probably want to consider STUB areas to keep the /32's only floating in your OSPF STUB area and summarize them at the area border.
Radius based pools rely on the accounting mechanism from AAA to learn whether addresses are in use or not.
This requires a strong Accounting back end on the radius-server and obviously proper delivery of your AAA records.
Don't implement radius pools without AAA System accounting.
Static address assignment (PPPoE/IPoE)
Requires you most of the times to inject /32's into the IGP for proper routing if not part of a summary.
The way to achieve this is via the radius attribute Framed-IP-Address (IETF number 8).
IP sessions
IP sessions address assignment is done via a DHCP Server. IOS-XR release 4.3.0 will come with an on board dhcp server.
In today's model the dhcp server is responsible for handing out addresses which are picked based on the "giAddr" field in the dhcp discover which is filed in by the DHCP Proxy component of the ASR9000.
Static addresses are defined within the dhcp server.
The advertisement is here more simple since the unnumbered interface to the subscriber session provides the subnet it is serving hence the inclusion of this unnumbered interface in your IGP will take care of the proper routing:
In this example we set the dhcp server to 81.1.1.2, the giAddr for pool selection is set to the red value to instruct the dhcp server where to pick an address from. The giAddr selection in this example is based on the dhcp option 60, vendor Class which is matching a hex string.
dhcp ipv4
profile AutoSelectGiaddr proxy
class MATCHALL
match option 60 hex 68656C6C6F mask 0
helper-address vrf default 81.1.1.2 giaddr 10.1.1.254
class HardPhone1
match option 60 hex 4861726450686F6E6531 mask 0
class HardPhone2
match option 60 hex 4861726450686F6E6532 mask 0
helper-address vrf default 81.1.1.2 giaddr 172.28.15.254
relay information option
relay information policy replace
relay information option remote-id testme
relay information option allow-untrusted
interface Bundle-Ether100.2 proxy profile AutoSelectGiaddr
This combined with the following template configuration, the subscriber is unnumbered to loopback interface number 12.
dynamic-template
type ipsubscriber IPSUB
ipv4 unnumbered Loopback12
Which has then address in the same pool range as the giAddr and the dhcp server will want to set the default-router option to this value.
RP/0/RSP0/CPU0:A9K-BNG#sh run int lo12
Fri Mar 16 10:52:33.265 EDT
interface Loopback12
ipv4 address 172.28.15.254 255.255.255.0
Including Loopback 12 (passively) in your IGP will provide for proper downstream routing!
More information on the DHCP configlet is in the BNG training guide
Configuration can be applied to a subscriber via 3 methods and in order of preference from lowest to highest:
- Dynamic Template
- Radius/Access-Accept (also known as Policy PULL)
- COA (also known as Policy PUSH)
So that means that local template configuration can be overridden by RADIUS, which can be overidden by COA.
Here are a few examples on how to match a CLI Configuration to a radius attribute, full documentation is available in the XR configuration guide.
PPP timer configuration
It is very important for any BNG implementation to properly define your PPP timer configuration to make sure that sessions establish, also under load and that we are not prematurely timing out, or working on establishment while the peer already gave up.
The picture below shows the different stages of PPP and which timers apply that need evaluation.
The referenced timers can be configured on the dynamic template for PPP subscribers:
dynamic-template type ppp <tmpl_name>
ppp max-configure <#>
ppp max-failure <#>
ppp timeout retry <sec>
ppp lcp delay <sec>
ppp lcp renegotiation ignore
ppp authentication { pap | chap | ms-chap }
keepalives { disable | <sec> }
ppp max-bad-auth <#>
ppp timeout authentication <sec>
ppp ipcp peer-address pool <poolname>
ppp ipcp mask <mask>
ppp ipcp { dns | wins } <server ip>
ppp ipcp renegotiation ignore
ipv4 unnumbered <interface>
Quality of Service
QOS application to the session can be done via static configuration in the dynamic template, or the policy-map name can be referenced via Cisco AVP's in RADIUS access-accept or COA requests.
This requires the configuration of the policy-map to be present in the XR configuration.
QOS can be applied at the port level, vlan level (subinterface) and at the session level with classes in a hierarchical manner.
This constitutes the 4 layers of QOS.
The following pictures shows the basics of the 4 layer QOS:
Which can be further expanded on in this picture:
Parameterized QOS
Parameterized QOS is a very powerful option in ASR9000 BNG. It allows you to construct the policy-map and its values from the AAA server.
pQOS only requires the class-map definitions to be present in XR configuration.
You can setup hierarchical policy-maps without a problem using pQOS.
Note however that if you have defined a static policy-map via configuration to the dynamic template or from radius
then you cannot override it or modify it with pQOS.
If you desire to use pQOS the initial policy-map needs to be pQOS'd also.
You can modify pQOS policies on a per class basis and while the session is active add or remove classes dynamically as you go!!
To see pQOS in action and the benefits see this video on demand BNG demo on YOUtube
VSA definition
Understanding the format of the Vendor Specific Attribute for Parameterized QOS (pQOS).
VSA 9,1 is Cisco-Avpair
TARGET:
sub – The QoS policy attached to the subscriber session. This implies that the CoA/Access-Accept target must be a subscriber session.
CLASS:
(class-default)
This example identifies the class “class-default” on the parent-policy.
(class-default,voip)
This example identifies a leaf class “voip”. This class will be added to or removed from a nested child policy specified under the class “class-default” of the policy attached to the target.
(class-default,voip-aggregate,voip-1)
This example specifies a leaf class “voip-1”. This class will be added to or removed from a nested child policy specified under the class “voip-aggregate” of the policy which is in turn nested under “class-default” of the policy attached to the target
ACTIONS:
See this next section on how to map IOS-XR MQC (modular Qos configuration) actions to the parameterized QOS equivalent.
Supported pQOS actions:
Examples
Policing
CLI Equivalent: police <bps> <burst-normal> <burst-max> <burst-size> conform-action <action> exceed-action <action> violate-action <action>
police(CIR,CBS,PIR,PBS,conform-action,exceed-action,violate-action)
VSA value: qos-policy-in:add-class(sub,(voip),police(200000,9216,0,0,transmit,drop,drop) )
Shaping
CLI Equivalent: shape <shape-rate>
VSA value: qos-policy-out:add-class(sub,(class-default),shape(14700))
For complete COA examples check the Change of Authorization document
Coming soon!!
Unlike IOS, ASR9000/XR BNG has no explicit call admission control configuration as that is natively build into the system.
When resources are running slow or the system experiences internal back pressure to do slow responses on function calls
the number of in flight sessions increases which are then throttled back down at the access interface.
Most of the time you may want to control the number of in flight sessions so you can streamline the number of radius access requests that are being sent to the RADIUS server.
The way to monitor and control the in flight sessions is via this command :
RP/0/RSP0/CPU0:A9K-BNG#show pppoe summary total location 0/rsP0/CPU0
....<output omitted>...
Flow Control
Limit 2000
In Flight 0
Dropped 0
Disconnected 1
Successful 9
Limit means the number of in lfight sessions you want to control on a per node basis. A node constitutes a pppoe processing entity which is either the LC for phyiscal interface based sessions or the RSP when using bundle interfaces. This number is configurable via the followingcommand:
RP/0/RSP0/CPU0:A9K-BNG(config)#pppoe in-flight-window 2000
Default value is 200, recommended for RP-based subscribers. Recommended value for LC-based subscribers is 50.
In Flight is the number of sessions we are currently handling and have not fully established yet. A fully established session is the signal from the session control entity that the subscriber interface is up and forwarding
Dropped are the sessions when the in flight session number exceeds the Limit set.
Disconnected how many sessions ahve been disconnected for normal reasons, eg send a PADT etc.
Successful is the number of sessions that we successfully established over time on this node
AAA
Throttling
This feature supports throttling of access (authentication and authorization) and accounting records
that are sent to the radius server. Throttling rate can be configured separately for access
and accounting requests. When the threshold is reached for a server, no more requests of that type
will be sent. A retransmit timer is started when the threshold limit is reached. After expiry of
the retransmit timer, the queue is checked to see if the outstanding requests is less than the
configured limit. If so, then the request is sent out to the radius server
AAA throttling can be configured globally or at the server group level. Throttling configured
for the server group will take precedence
configuration:
radius-server throttle access 100 access-timeout 3 accounting 150
aaa group server radius my-grp
server 1.74.11.103 auth-port 1812 acct-port 1813
server 1.76.30.103 auth-port 1812 acct-port 1813
throttle access 200 access-timeout 3 accounting 120
Subscriber Services
Services constitute a set of features under a common umbrella.
These features are enabled together constituting the service defintion.
For instance you can allow users to access or deny parts of the network, or modify its qos parameters.
Services are defined via the dynamic template in IOS-XR.
dynamic-template type { ppp | ipsubscriber | service } <tmpl_name>
<attribute-list>
There are 3 types of templates:
ppp: for configuration on PPP sessions (both PTA and LAC)
ipsubscriber: for configuration on IpoE sessions
service: contains configuration commands for all types of sessions
The following is an example of a service definition:
dynamic-template
type service SERVICE_1
service-policy output testme
ipv4 access-group lab-video ingress
The following set describes a few RADIUS/COA templates to activate or deactivate services on a subscriber.
Operation |
RADIUS attributes set to achieve that operation |
Account Logon |
attribute 44 “<string>” attribute 1 "<username> Cisco-avpair = "subscriber:password=<subscriber password> Cisco-avpair = "subscriber:command=account-logon" |
Account Logoff |
attribute 44 “<string>” Cisco-avpair = "subscriber:command=account-logoff" |
Account Update |
attribute 44 “<string>” Cisco-avpair = "subscriber:command=account-update” <radius attributes to set/update> |
Service Activate |
attribute 44 “<string>” Cisco-avpair = "subscriber:command=activate-service" Cisco-avpair = "subscriber:service-name=<service-name>” |
Service De-activate |
attribute 44 “<string>” Cisco-avpair = "subscriber:command=deactivate-service" Cisco-avpair = "subscriber:service-name=<service-name>” |
Attribute 44, or accounting session ID is always used for fastest lookup of the subscriber session.
The subscriber password is a special encoded string by providing a seed authenticator together with a hashed MD5 password of that seed.
COA tool is available on the forum for Windows, MAC/OSX and Linux.
Redundancy is obviously very important these days and while IOS-XR supports process restart and process crashes without affecting the subscribers there are additional options available to increase your density and protect against failures.
Cluster and Satellite are part of the ASR9000's nV concept (Network Virtualization).
Cluster
Cluster is the concept of binding two physical chassis together into 1 logical unit. The control plane is extended via RSP on board 1 or 10G interfaces while the data plane is extended via 1 or more physical interfaces on the linecards.
So when building a bundle from the access side, if you link them to each individual chassis you'll have an active active bundle with failover between chassis!
Also the physical ASR's don't need to be on the same location. Only the control plane extension needs to have minimum latency (~<20msec).
Satellite
Allows for port extension into a simple 1RU chassis with large 1G port fan out.
The Satellite connects via 1 or multiple 10G uplinks ot the ASR9000 host.
You can statically pin ports to an uplink or share an uplink via a bundle to multiple ports.
Satellite interfaces appear in teh ASR9000 config as if they were physically on the ASR9000.
Satellite interconnection options:
nv
satellite 100 •ß define satellite ID
description my lovely satellite
type asr9000v
satellite 101 •ß define satellite
description your lovely satellite
type asr9000v
interface TenGigE 0/2/0/2
nv
satellite-fabric-link satellite 100
remote-ports
GigabitEthernet 0/0/0-9
interface bundle-ethernet 10
nv
satellite-fabric-link satellite 101
remote-ports
GigabitEthernet 0/0/10-19
On top of these bundle interfaces you can enable BNG.
Cluster and Satellite together
Wholesale Models
Most of the documentation here has been talking about locally terminating the subscribers on the BNG for regular access. Obviously there deployment models whereby a provider may like to just provide the initial termination on behalf of the wholesale provider.
Per access technology there are different options available.
PPP
PPP sessions can either be locally terminated, also known as PTA, or forwarded to the wholesale provider with 2 main options:
- L2TP tunneling
- RAMPLS
IP sessions
IP sessions only have one option for wholesaling which is inserting the subscribers in a VRF and using MPLS VPN to transport the data traffic to the wholesale provider.
RAMPLS
(Remote Access into MPLS-VPN) Is the concept of terminating the subscriber sesisions locally on the BNG and insert them in a specific vrf. This vrf is a separate routing context and using MPLS-VPN to transport the users traffic to the wholesale provider.
L2TP
Layer 2 Tunnelling Protocol is the concept of transporting the PPP session over to the wholesale provider's LNS.
ASR9000 can only function as LAC which basically means that after authentication we are creating a tunnel or inserting the user into an existing tunnel over to the LNS.
Doubledip
L2TP has as key advantage that the subscriber's PPP session is sent over to the LNS. This allows the LNS to have full control over the PPP session including authentication.
RAMPLS doesn't have such an option as the only Authentication stage is done on the BNG one time.
The concept of "double dip" is a phenomenal extension allowing you to use a local radius server on teh BNG and then contact the wholesale provider's AAA server and merge the profiles together:
On the ASR9000 BNG you can filter the attributes from the retailer to make sure that they don't override the user's vrf for instance like this:
radius-server attribute list RETAILER_X_ATTR_LIST
attribute <accepted or rejected attribute-list>
aaa group server radius RETAILER_X_SG
authorization reply { accept | reject } RETAILER_X_ATTR_LIST
vrf RETAILER_X_VRF
server-private 10.10.10.100 auth-port 1645 acct-port 1646
This server group referenced can be used in a control policy as an additional authenticate/authorize action under the session-start event for instance.
If your BNG deployments is high scale, these are some of the best practices to follow:
ICMP Unreachables
ICMP unreachables can significantly increase the CPU utilisation on line cards, especially if security access lists are enabled on seubscriber interfaces. You can disable the generation of ICMP unreachables in subscriber access interface configuration or dynamic template configuration:
ipv4 unreachables disable
or in radius profile:
Cisco-avpair="ipv4-icmp-unreachable=1"
ARP
In deployment scenarios with IP unnumbered and loopback interfaces with multiple secondary IP addresses, the ARP table size grows very quickly. Since on subscriber interfaces the MAC to IPv4 mapping is known through either DHCP or PPPoE, ARP entries are not required. On XR release 5.3.3 and later you can prevent the creation of ARP entries associated with subscriber interfaces by configuring:
subscriber arp scale-mode-enable
For more information on high scale ARP, refer to: https://supportforums.cisco.com/document/12766486/troubleshooting-arp-asr9000-routers.
Related Information
- BNG demo on YOUtube
- Using COA (Change of Authorization) tool
- Debugging PPPoE sessions
- Configuration Walkthrough
- Training guide
Special thanks to Sabrina Pittarel for some of the great visualizations seen in this document
and Nanjangud Sreekanta Prasad providing packet trigger and dhcp lease limit sections
Xander Thuijs, CCIE #6775
Sr. Tech Lead ASR9000
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Dear thuijs,
We have "ipv4 unreachables disable" on dynamic template, so there is no unreachable sent from BNG regards subscribers interface.
Some subscribers have PathMTU dicovery problem as ICMP unreachable are not sent.
ICMP xx.xx.xx.xx unreachable - need to frag (mtu 1492), length 76
IP (tos 0x0, ttl 58, id 0, offset 0, flags [DF], proto ICMP (1), length 1493)
We are trying to enable via RADIUS attribute, but no success.
Cisco-avpair="ipv4-icmp-unreachable=0"
ICMP unreachable still does not send.
show ipv4 intervace BExxxx.xxxx.pppoexxx still shows:
ICMP redirects are never sent
ICMP unreachables are never sent
ICMP mask replies are never sent
ASR 9010, IOS XR 6.2.3
Do you have any idea?
Thanks, Imre
Page 115, #25 " - No matter the value is 0 or 1, downloading this avpair cause the ipv4 icmp unreachables disabled on the session interface."
Not good for us!
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hi, Xander:
Hopefully you'll be able to help me with the following. Is it possible to format a DHCP field that comes in in HEX format so that you send it to the radius server as ASCII and truncate it?
In particular I'm referring to the remote-id-tag that for example comes in as "000007db302f332f30", which translates to U0/3/0 in ASCII. I need to be able to send "0/3/0" ASCII string to the radius server instead of 000007db302f332f30 (and cut the U from the ascii translation). Is this even possible?
c.
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hey Xander,
Running into a problem with BNG over PWHE. I'm seeing packets sent from the far end PE but drops on the BNG. Any ideas or should we engage TAC?
!!! Far end
PW: neighbor 10.46.1.115, PW ID 3033, state is up ( established )
Statistics:
packets: received 0, sent 1058
bytes: received 0, sent 90984
!!! BNG
PW: neighbor 10.46.0.11, PW ID 3033, state is up ( established )
Statistics:
packets: received 0, sent 0
bytes: received 0, sent 0
show controller np counters:
[np:NP0] PARSE_PWHE_ING_UIDB_MISS_DROP: +38
regards
Jon
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hello Xander,
We're in a process of considering BNG evolution in our network and PWHE seems to fit very well. In order to adopt it, we'll have to redesign and mix LC based sessions and PWHE based sessions on the same box. LC based will terminate on existing 10G modules and PWHE will terminate on new 100G modules. As we redesign, the LC based will get fewer and the PWHE ones will increase. In the end the vast majority will be PWHE based and probably some LC based will remain.
First, do you have any concern for such approach? Do you see anything blocking? In a small scale (<30K session), the mixed scenario has been tested and seems to work very well.
My major concern is what happens when we get to a higher scale. I can't get a clear answer from AS and from documentation when both types exist simultaneously. I have been told to watch for the 64K per NPU limit for Tomahawk, but no clear answer for the total scale. Apparently, total RP based is not added to the total LC based limits. Is there any document that describes it? Could you elaborate a bit how to approach it and make my calculations?
Many thanks
George
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hello guys
I have followed this forum in several situations and have found many answers
My question however is about hardware
I have a 9010 with RSP-440-SE with A9K-MOD80-SE
And it runs BGN Services well
I have another 9010 that I am putting into operation and the plates are:
RSP-440-SE with an A9K-8T-L ... And that has been giving me problems. I'm using bundle-Ether interfaces
The sessions simply do not go up, neither log nor debug
I believe that the A9K-8T-L is not compatible with BGN services (PPPoE Server)
Am I right?
Any consideration?
- Mark as Read
- Mark as New
- Bookmark
- Permalink
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Wonderful document!
What about per-user QoS scaling ? I wonder what is the best pratice to setup residential access QoS without triple-play services and HQoS settings.
For example a simple internet access could be done with simple policing in outgoin traffic (from BNG to end-user) instead of shaping ?
Using shaping on total per-user sessions requires to control the queque lenght to prevent buffers saturation ?
David
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Would it work to push them to a non-pay walled garden if the subscriber is authenticating on QinQ tags? Seems like the session would need to authenticate first so the subscriber has a session before they could be redirected somewhere. Thanks
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hello everyone,
and thanks to everyone helping here
I am trying to configure a static ( routed ipsubscriber) using ASR9001 but with no luck so far.
the plan was to terminate the client's pppoe connections on an edge router then route the aggregated traffic to the ASR router because I need to route some of the clients' traffic to another (3rd) router.
the config is basic for testing purpose:
dynamic-template
type ipsubscriber TMP_1
type ipsubscriber TMP_2
service-policy output PROFILE_1
interface Loopback1000
ipv4 address 10.86.255.1 255.255.255.255
interface TenGigE0/0/2/1.11
ipv4 address 172.23.24.1 255.255.255.0
service-policy type control subscriber CMAP
encapsulation dot1q 1024 second-dot1q 11
ipsubscriber interface
router static
0.0.0.0/0 172.19.19.1
10.144.0.0/12 172.23.24.2
class-map type control subscriber match-any CM_1
match source-address ipv4 10.0.0.1 255.0.0.0
end-class-map
policy-map type control subscriber CMAP
event session-start match-all
class type control subscriber CM_1 do-until-failure
1 activate dynamic-template TMP_1
2 activate dynamic-template TMP_2
end-policy-map
the result is the traffic getting routed through the interface instead of creating static subscribers.
the debug ( debug ipsubscriber ma all) show this error:
LC/0/0/CPU0:May 13 22:43:18.226 : ipsub_ma[250]: EVENT: t1 TP779: (AFI All) Retry flag set/unset (0) for Static Parent interface (TenGigE0/0/2/1.11)
LC/0/0/CPU0:May 13 22:43:18.226 : ipsub_ma[250]: EVENT: t1 TP473: (AFI All) FSOL: Incrementing session usage to 1/1 for category 0 on TenGigE0/0/2/1.11: result No error (0)
LC/0/0/CPU0:May 13 22:43:18.226 : ipsub_ma[250]: FSM: t1 TP434: (AFI IPv4) Interface creation done: access-interface (TenGigE0/0/2/1.11), subscriber-ip (0.0.0.0),subscriber-mac (ffff.ffff.ffff), outer ucv (0x400), inner ucv (0xb)
LC/0/0/CPU0:May 13 22:43:18.226 : ipsub_ma[250]: FSM: t1 TP753: (AFI IPv4) Interface creation done: access-interface (TenGigE0/0/2/1.11), uplink GRE key (0), downlink GRE key (0), subscriber default gw mac (0000.0000.0000)
LC/0/0/CPU0:May 13 22:43:18.226 : ipsub_ma[250]: FSM: t1 TP395: (AFI IPv4) FSM state change for interface (0x0), access-interface (TenGigE0/0/2/1.11), subscriber-ip (0.0.0.0), subscriber-mac (ffff.ffff.ffff), subscriber-label (0x0)
LC/0/0/CPU0:May 13 22:43:18.226 : ipsub_ma[250]: FSM: t1 TP396: (AFI IPv4) FSM state change for interface (0x0), event (fsol-received), old-state (Initialized), new-state (Control-policy executing)
LC/0/0/CPU0:May 13 22:43:18.227 : ipsub_ma[250]: FSM: t1 TP291: (AFI IPv4) iff-session-start: interface (0x0), access-interface (TenGigE0/0/2/1.11), subscriber-ip (0.0.0.0), subscriber-mac (ffff.ffff.ffff), subscriber-label (0x0), state (Control-policy executing)
LC/0/0/CPU0:May 13 22:43:18.227 : ipsub_ma[250]: FSM: t1 TP804: (AFI IPv4) Extn Trace of TP291: interface: (0x0), access-interface:(TenGigE0/0/2/1.11), sub-label: (0x0), subscriber-ip6:(::)
LC/0/0/CPU0:May 13 22:43:18.227 : ipsub_ma[250]: PACKET: t1 TP778: (AFI IPv4) Special MAC Interface based session
LC/0/0/CPU0:May 13 22:43:18.230 : ipsub_ma[250]: ERROR: t1 TP103: (AFI IPv4) AAA session start response callback: interface (0x0), subscriber-label (0x400002e), trans-id (4294982278): error ('iEdge' detected the 'fatal' condition 'iEdge Resource not available' (2950991872)), aaa error (No error (0))
LC/0/0/CPU0:May 13 22:43:18.230 : ipsub_ma[250]: FSM: t1 TP395: (AFI IPv4) FSM state change for interface (0x0), access-interface (TenGigE0/0/2/1.11), subscriber-ip (0.0.0.0), subscriber-mac (ffff.ffff.ffff), subscriber-label (0x0)
LC/0/0/CPU0:May 13 22:43:18.230 : ipsub_ma[250]: FSM: t1 TP396: (AFI IPv4) FSM state change for interface (0x0), event (fsm-error), old-state (Control-policy executing), new-state (Error)
LC/0/0/CPU0:May 13 22:43:18.230 : ipsub_ma[250]: FSM: t1 TP170: (AFI IPv4) iff-error: interface (0x0), access-interface (TenGigE0/0/2/1.11), subscriber-ip (0.0.0.0), subscriber-mac (ffff.ffff.ffff), subscriber-label (0x0), state (Error)
LC/0/0/CPU0:May 13 22:43:18.230 : ipsub_ma[250]: FSM: t1 TP396: (AFI IPv4) FSM state change for interface (0x0), event (disconnect-event), old-state (Error), new-state (Disconnecting)
LC/0/0/CPU0:May 13 22:43:18.231 : ipsub_ma[250]: FSM: t1 TP412: (AFI IPv4) iff-disconnect: interface (0x0), access-interface (TenGigE0/0/2/1.11), subscriber-ip (0.0.0.0), subscriber-mac (ffff.ffff.ffff), subscriber-label (0x0), state (Disconnecting)
LC/0/0/CPU0:May 13 22:43:18.231 : ipsub_ma[250]: FSM: t1 TP409: (AFI IPv4) iff-do-disconnected: interface (0x0), access-interface (TenGigE0/0/2/1.11), subscriber-ip (0.0.0.0), subscriber-mac (ffff.ffff.ffff), subscriber-label (0x0), state (Disconnecting)
LC/0/0/CPU0:May 13 22:43:18.231 : ipsub_ma[250]: FSM: t1 TP809: (AFI IPv4) Extn Trace of TP409: interface: (0x0), access-interface:(TenGigE0/0/2/1.11), sub-label: (0x0), subscriber-ip6:(::)
LC/0/0/CPU0:May 13 22:43:18.231 : ipsub_ma[250]: FSM: t1 TP754: (AFI IPv4) iff-do-down-notification: interface (0x0), access-interface (TenGigE0/0/2/1.11), uplink GRE key (0), downlink GRE key (0), subscriber default gw mac (0000.0000.0000)
LC/0/0/CPU0:May 13 22:43:18.231 : ipsub_ma[250]: FSM: t1 TP395: (AFI IPv4) FSM state change for interface (0x0), access-interface (TenGigE0/0/2/1.11), subscriber-ip (0.0.0.0), subscriber-mac (ffff.ffff.ffff), subscriber-label (0x0)
LC/0/0/CPU0:May 13 22:43:18.231 : ipsub_ma[250]: FSM: t1 TP396: (AFI IPv4) FSM state change for interface (0x0), event (vaccess-intf-deleted), old-state (Disconnecting), new-state (Disconnected)
LC/0/0/CPU0:May 13 22:43:18.231 : ipsub_ma[250]: FSM: t1 TP414: (AFI IPv4) iff-cleanup: interface (0x0), access-interface (TenGigE0/0/2/1.11), subscriber-ip (0.0.0.0), subscriber-mac (ffff.ffff.ffff), subscriber-label (0x0), state (Disconnected)
LC/0/0/CPU0:May 13 22:43:18.232 : ipsub_ma[250]: FSM: t1 TP813: (AFI IPv4) Extn Trace of TP414: interface: (0x0), access-interface:(TenGigE0/0/2/1.11), sub-label: (0x0), subscriber-ip6:(::)
LC/0/0/CPU0:May 13 22:43:18.232 : ipsub_ma[250]: EVENT: t1 TP473: (AFI All) FSOL: Decrementing session usage to 0/0 for category 0 on TenGigE0/0/2/1.11: result No error (0)
this error: error ('iEdge' detected the 'fatal' condition 'iEdge Resource not available' (2950991872)), aaa error (No error (0)
also noticed that the router is not recognizing the IP and MAC of the clients :
"subscriber-ip (0.0.0.0), subscriber-mac (ffff.ffff.ffff)"
if I use the " ipsubscriber ipv4 routed" and " initiator unclassified-ip" instead of "ipsubscriber interface" the router will recognize only the mac/ip address of the pppoe aggregation router and still get the same iedge error
Kindly if someone can help ?
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hi Xander!
We faced an issue with installing linecard A9K-MPA-4X10GE into ASR9001.
Currently we have about 21K subscribers terminated on ASR9001 (some of them are dual stack) on RP bundle. As 4x10G is not enougth, we shuted down ASR, installed A9K-MPA-4X10GE linecard (documentation tells that it's supported with BNG) and powered it again. Sessions started to connect up to 17K subscribers. We don't have any subscriber limits. But with this linecard number of connected subscribers don't increase more then 17K. We tried to change linecard, we have changed software to 6.7.3, but without success. After removing this card, problem has dissapeared, all 21K subscribers are connected.
Can you give an advice, may be we need to add some configuration to this card, or change something?
Thanks!
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hi xander
Can we get an example of Diameter for Prepaid. ?
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Extremely detailed guide. Appreciate it!
- Mark as Read
- Mark as New
- Bookmark
- Permalink
we have a limitation with the pppoe connected subscribers which is limited at 4094, my device is ASR9904, and we have a license of 128K subscribers. the device consumes a license typically. Can you assist me in solving this limitation issue?
- « Previous
- Next »
