Leah Davis
Level 5
Level 5
Call Accounting/CDR are available with the UC500, based on existing CME feature.
CME GUI has a call history report, not very feature rich but will
tell you calls though the system.
Today customer has a number of choice choices;
1) Use a External FTP server or store on flash memory* (Easy and Reliable implementation)
You can configure the UC500 / CME to store CDR's on the UC500 in a CSV file.
This CSV file can the be uploaded of the box using FTP and manipulated as required
* writing data to flash is not recommended since UC520 flash is only 128M and is near full at this point
Setup & Configuration Guide
2) Use a External Syslog Server (Easy Implementation)
You can deploy a separate Syslog server/PC to collect the CDR Records.
You can monitor call activity information through syslog messages and call detail records (CDR).
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/managcme.html#wp1076106
3)
Use a External Radius Server (Advanced Implementation)
You can deploy a separate Radius server/PC to collect the CDR Records.
These records could then be
exported to Excel or some database application and create/run reports for their use:
Sample Configuration
Sample CDRs
4) Use a 3rd party billing tool that integrates with Cisco e.g.
Tri-Line - TIM Plus and TIM Enterprise, http://www.tri-line.com/cisco - Cisco IVT tested and approved
StoneVoice (http://www.stonevoice.com/Howtobuy/Partners/tabid/779/Default.aspx) -  Officially supported on UC500
CAAB/TSA  (www.caab.net) - Australian Company
Calltrak (http://www.calltrak.com.au/) - Australian Company
Veramark Call Accounting Software, VeraSMART (http://www.cisco.com/go/sbcsapps)
Other Reports Account/Reporting (Subsets of calls)
1) Use CUE historial reporting
Note: Only calls that go to CUE (e.g the Auto Attendant) will be reported on.
https://www.myciscocommunity.com/docs/DOC-4235
2) Use BACD reporting
Note: Only calls that go thru BACD (e.g the Call Queueing) will be reported on.
Basic Setup Guide
Excel Macro for Reporting - Download (cisco.com ID required )
treisinger
Community Member
voip-monitor provides a CDR reporting and monitoring service. There is no need for additional software or hardware required. You configure simply the RADIUS server for CDR accounting on your UC500 or CME/CUCME and receive the reports and alerts via e-mail.
http://www.voip-monitor.net
http://www.voip-monitor.net/products-reports.html
Kenneth McCoig
Does anyone know if the 3rd party packages suggested above or any other tool for that matter, provide account code verification? We are looking for something that will prompt the user on outgoing calls to enter an account code, then have it verify the code to make sure its valid, and if so let the call dial out.
Any help is appreciated.
Thanks!
-Kenny
Does anyone know if there is a way to send live TAPI events from a UC560 to a third party solution instead of CDR's.
dbaker85749
I just found out about the very best Call Accounting software in the market.
It is from ISI-info.com Somm told me about it.
Cheap and it sells CME systems.
Yue bun Yuen
cannot access to get this file. anyone has the pdf format?
https://communities.cisco.com/docs/DOC-7314
Kay Tobin
The Cisco UCME / UC500 can be configured to send RADIUS or SysLog events. RADIUS recommended. Feel free to use info in these docs:
http://docs.tri-line.com/pages/viewpage.action?pageId=4817083
