on 08-02-2012 03:03 PM
The Cisco UC500 team is pleased to announce the impending release of Smart Call Connector (SCC) Version 2.2 Beta. This is a Beta of the maintenance release that that includes udpates for all the CallConnector components -- Server, Advanced Client, Operator and Toolbar. These updates are also available for Cisco CME in the Unified CallConnector (UCC) versions. Please do not use this a business critical system. This is version that you can use to test the new version.
Whats new in SCC 2.2
Download Beta from here
username: scc22beta
password: jingle
Important Bug Fixes:
Please post new bugs and issues found. Some of the important bug fixes are summarized below. For details, please review the release notes document in the download section.
Server:
Advanced Client:
Operator:
Toolbar:
Hi, i have been using this for a few weeks now and i have some bugs to report:
OK, so further to this, its got to do with refreshing the VoiceView display area...
Thanks for the feedback Jeremy, we are looking into it now.
Hi, we have tested the beta version this week. The beta version is much better than the version 2.01.012.
Since we have installed the beta version we haven't any crashes. That's very nice.
We have found the following points, which are not optimal for us:
Another big point would be the terminal server support. Would this be possible with the new version?
Hi Dominique:
1. By default the logs are presented with the latest call at the top. This default can be changed by clicking on the date/time field to reverse the sort order. To return back to the default, click on that field again.
2. Presence status showing "In a Meeting". This issue has come up as a result of the bug fix and is being investigated.
3. Size of window width -- there is a maximum setting. It cannot be made larger that that size.
4. As you have noted, that capability is in the Global Search. The are user interface issues that have caused us to take this approach. For example -- most users want to search only in the selected directory.
SCC Team
Hi Dominique:
Thank you for your input. There are no plans to provide terminal server support at this time.
SCC Team
Hi Jeremy:
The VoiceView window is updated with a push notification from CUE. Please see tech-notes below for the setup information:
https://supportforums.cisco.com/docs/DOC-13290
SCC team
Hi Jeremy,
The 3 options: subscribe notify, include envelop and mwi on/off number needs to be configured like the screenshot below + ttps://supportforums.cisco.com/docs/DOC-13290 in order for Voice View to be updated automatically
SCC CallConnector Team
What about the extension mobility? Does the new version support the extension mobility?
Hi SCC Team,
I have again a problem with the call logs:
I try to changed the sort order by clicking on the date/time.
But either the log is like this:
The newest call is on page one on the button
or if i click the date/time field again:
the oldest call is on page one on the top.
So you can see it is not possible for me to show the newest call on page one on the top.
I hope you can help me by this problem.
Dominique
So are there any new builds for this available? How far away is the release version?
