Alberto Montilla
The Cisco Smart CallConnector Toolbar is a free solution for the Cisco Smart Business Communications System (SBCS) that integrates your phone functions directly into Microsoft Outlook and Internet Explorer (32 bit windows only). It provides toolbars that allow a user to make and answer calls from these applications, displaying incoming call information in a pop up window. Integration with Outlook allows you to click on a contact, whose work phone number is then presented in the dialing field. The toolbar is easy to install and use and provides inmediate value by increasing you call handling productivity.
[toc:faq]
Documentation
Download Software
  • cisco.com (for partners with a service contract)
System requirements
  • PC: 32-bit Windows operating system. Windows XP (with SP2), Vista, and Seven are supported. 64-bit support is scheduled for a later release.
  • PC: 50 MB free hard disk space
  • PC Toolbar applications: Microsoft Outlook 2007, IE 6.x (with SP2), 7.x, 8.x
  • IP Phones: Cisco 7900, Cisco SPA 500, Cisco SPA 300 series
  • Software pack 7.1 or later
  • UC520, UC540 and UC560 systems.
  • Optional - Access to Cisco Configuration Assistant or Office Manager may be required to get IP Phone Username and Password.
Application Notes
SCC Toolbar - Outlook dialing
SCC Toolbar Hotkeys/shortcuts localization
SCC Toolbar - Phone user name and password recovery
Related Products
Additional Support
The Cisco Smart CallConnector Toolbar is supported through the Small Business Support Community.
FAQ
What's the Smart CallConnector Toolbar (known as SCC Toolbar)?
It is an Computer Telephony Integration Application, commonly known as Click-to-dial, which allows the user to make and receive (UC500) phone calls by using your Windows-based personal computer.
How much does the Smart CallConnector Toolbar cost?
SCC Toolbar is a free application to download by any UC500 user
Where is the SCC Toolbar available for download?
It is available in cisco.com for download. Look at this document for links
Is it there any limit of using the SCC Toolbar?
No, as long as used with a purchased UC500 with appropriate support contract
What are the call control platforms SCC Toolbar support?
UC520, UC540 and UC560 models
Does the SCC Toolbar support presence?
No, it does not. You need to upgrade to the SCC Advanced Client + SCC Server
Does the SCC Toolbar support Instant Messaging (IM)?
Does the SCC Toolbar support multiple directory integration, such as LDAP Active Directory?
Can I use the SCC Toolbar with a 64 bit Windown Operating System?
Not yet. Current SCC Toolbar supports 32 bit OS only. 64 bit version is planned for a future release
Can I use the SCC Toolbar with another platform outside of UC500?
No, it will not work and also not supported
How can I get support for the SCC Toolbar installation?
We suggest you download the Quick Reference Guide. It is a fairly easy installation process. If you still require further assistance, use this support community to ask for questions.
During installation, the tool ask me for the phone user name and password, how can I obtain it?
Talk to your system administrator if you don't know the name. He can gather this info using CCA and/or Office Manager. The default password (if not set) is 123456.
davidbrajort
Hi Alberto,
Do you have any status report on the x64 version of SCC Toolbar ?
Alberto Montilla
Dear David;
Making progress. We should be able to start BETA during mid January. FCS is planned for end of february 2011.
cisco
It works fine with outlook 2010 32bit.  How can I have it dial an international number in the format (+number) eg. +456789. it works fine with domestic (+1number)
kripton
Community Member
Dear Alberto,
Do you have any news about SCC Toolbar x64 version?
Miljan
OldCCIE
Any idea's on when the documents here will be updated for the 2.1 release?
Jeremy Koch
This does not work in a Windows 7 64-bit / Office 2010 32-bit install scenario...very annoying...
Phil Kernick
Microsoft strongly suggest installing Office 32-bit on Windows 64-bit.  Which is what we have.  It's really disappointing to see that this standard deployment scenario means that the Outlook Toolbar won't work.
Can we please have a 32-bit toolbar on 64-bit Windows.
Chris Foot
I see that this is a free download, we have recently purchased a UC540W and am keen to try this out but unfortunately we do not have a service contract, is there an alternate download location for this?
Eckhard Eilers
Hi, what is the official CTI Solution for Windows 7 64-Bit?
Will there be any new releases for Windows server 2012 or other newest Windows OS ?
ChadYost1
Community Member
I see where this is End of Life.  Is there a replacement?  Our users use the click to dial all the time!
Jeremy Koch
this is dead....like cisco is to me :(
