01-19-2011 01:10 AM - edited 08-28-2017 01:30 AM
This is the SRP500 configuration for Telmex (Mexico) ADSL Services, big thanks to Rogelio Valtierra.
Below is the configuration for Telmex ADSL Service using dynamic IP Address:
TBC
This is very Helpful. But I have a Question :
If a have a static ip address with Telmex, it's the same configuration? Tanks.
Unless you have been told othewise by Telmex, the configuration will be the same as above. For PPP, addressing is generally assigned dynamically - in your case, you are always assigned the same (static) address.
Andy
Hi:
Yesterday I was setting up an SRP527W with Telmex, but not work. The 2 LEDs are green (CD-DATA), username and password correctly, but Telmex did not assign a Public IP to the router. Any ideas?
Regards.
Julio
Julio,
Please login as admin go to quick setup -> WAN Setup and be sure that:
Encapsulation = PPPoE,
Multiplexing = LLC
VPI/VCI Autodetect o Disable
and most important:
VPI=8
VCI=81
Rogelio V.
This is my current settings and it worked yesterday (Dynamic IP Address assignment over Telmex) :
Quick Setup - - > Basic Configuration Setup - - > Wan Setup
Encapsulation : PPPoE
Multiplexing: VC
QoS type: UBR
VPI/VCI Auto Detect
Virtual Circuit
VPI 8
VCI 81
PPPoE Settings
Interface Setup - - > WAN - - > Internet Setup
DSL Modulation: ADSL2+
MTU: Manual Size 1492
Julio,
It is the type of encapsulation, both are pretty much the same, VC-MUX is a form of network traffic control. It is used in situations where multiplexing is preferable to switching.
If you take a look on your old the modem, it is configured to work with LLC.
You may try to test latest SRP520 Maintenance Release 3 (MR3)
https://supportforums.cisco.com/docs/DOC-11342
regards
Rogelio V.
