06-30-2020 05:54 AM
Hi Members,
I have set an Sg300-28 Cisco in Router mode with the following config but only the interfaces on vlan 1 can reach internet.
Vlan 2 pinging to internet gateway 192.168.100.1 fails. I have tried up route but nothing works.
Any pointers will be appreciated.
Config;
switch3fdb71#sh running-config
config-file-header
switch3fdb71
v1.3.7.18 / R750_NIK_1_35_647_358
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
More: <space>, Quit: q or CTRL+Z, One line: <return>
bonjour interface range vlan 1
hostname switch3fdb71
interface vlan 1
ip address 192.168.100.77 255.255.255.0
no ip address dhcp
interface vlan 2
name tlan
ip address 192.168.7.1 255.255.255.0
interface gigabitethernet1
switchport mode access
interface gigabitethernet2
switchport access vlan 2
exit
ip default-gateway 192.168.100.1
Solved! Go to Solution.
07-14-2020 03:05 AM
The confiig worked. Added a static route on Huawei to 7.0 with gateway as .77 and then plugged in a device to gi2. I was formerly usng ping...source with the interface not having anything plugged in reason why it was failing. was configuring the switch from gi1.
06-30-2020 06:28 AM
If the Device already setup in router mode.
you need route required as below :
ip route 0.0.0.0 0 0.0.0.0 192.168.100.1
Still have issue post complete config alonng with show ip route output.
06-30-2020 06:42 AM
06-30-2020 06:49 AM - edited 06-30-2020 06:50 AM
Ok you have route back entry for network 192.168.7.0/24 from 192.168.100.1
EDIT :
Please also confirm the device Configuired on IP 192.168.7.X able to ping 192.168.7.1 ?
06-30-2020 08:38 AM
06-30-2020 08:49 AM
I have no idea about that product, Google may help you.
just did one quick search here is document to add static route not sure if that work for your model.
06-30-2020 11:13 AM
Thanks for the pointer. I have googled about the cisco Sg-300 series and read a lot about it but it ain't a straight forward config as the catalyst.
I have created the static route back to 7.0/24 with different gateways (7.1,100.1,100.77) but nothing works.
I hope the gurus or Cisco employees in this forum can help crack this once and for all.
06-30-2020 11:34 PM - edited 07-01-2020 12:09 AM
EDIT :
Sorry to hear that not work, please post all the screenshot cisco device and Huawei to understand
07-01-2020 08:29 AM
07-14-2020 03:05 AM
