How to setup failover between Switches
CTS-Tech1
Have a SLM2024 Switch that I need to connect to 2 HP Switches. The HP Switches have a trunk between themselves and can communicate fine.  They are not stacked switches.
I want to setup a network connection to each HP Switch, but do not want to create a loop.  If HP Switch A goes down and loses connection to the SLM2024, HP Switch B needs to be able to communicate to the SLM2024.
How do I set this up?
Tom Watts
Hi CTS, if spanning tree is being ran, a network loop wouldn't be possible. So you should be able to run redundant wires and have one port is a blocking state due to spanning tree mechanism.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
