CONNECT_FAILED(35) to satellite server
kjp1231
I am trying to register an ASAv via my Satellite server but when I test the smart call home profile via CLI to my satellite server I get this message.
call-home test profile License
INFO: Sending test message to https://F.Q.D.N/Transportgateway/services/DeviceRequestHandler...
ERROR: Failed: CONNECT_FAILED(35)
I can't find anything out about this message
Yes, support had me change to http instead of https. Don’t know why https wouldn’t work. I would think the preference would be https
5 Replies 5
Walter Thompson
Hi kjp1231,
What ver are you running?
Run the following debugs to help narrow the issue down and share the output here.
debug call-home smart-licensing all
debug license agent all
debug ip http client all
Scap the debug call-home smart-licensing all and instead use only debug call-home all.
I am running ASAv version 9.14(1) and satellite version 7-201907
I was able to 'debug call-home all' and 'debug license agent all' but the other debug commands didn't work.
Debug output shows -
ssh: processing test(Test) SCH Configuration Test
ssh: [0] dispatching test message to https://F.Q.D.N/Transportgateway/services/DeviceRequestHandler
ssh: Dispatch to destination https://F.Q.D.N/Transportgateway/services/DeviceRequestHandler
ssh: Opening dispatch channel: httpc/2/X.X.X.X/443/ssl/verify/sch//
ssh: Opened dispatch channel: httpc/2/X.X.X.X/443/ssl/verify/sch//
ssh: upload 2737 bytes
R13-SDWAN-FW01# ssh: http request to https://F.Q.D.N/Transportgateway/services/DeviceRequestHandler failed, rc -1
ssh: [0] Dispatch message(52) test to https://F.Q.D.N/Transportgateway/services/DeviceRequestHandler failed: CONNECT_FAILED(35)
@kjp1231, did you ever get this issue resolved?
